O-ring chain lube, what are you using?
Started by Grappa, May 14, 2008, 01:21:37 PM
ScottRNelson
Quote from: Dan on May 15, 2008, 02:15:15 PM
WD40 is pretty much kerosene.
Where did you get that from?
It's quite a bit different.  Kerosene leaves less of a residue when you use it, and doesn't work nearly as well for freeing stuck and rusted bolts and things.
Ddan
Ducati Monster Forum at
www.ducatimonsterforum.org
S4ROB
"Guns. You think you have enough, until the ZOMBIES come."
Gunslinger's Journal
ScottRNelson
Quote from: Dan on May 15, 2008, 02:28:55 PM
http://en.wikipedia.org/wiki/WD-40
I guess 'pretty much' may have been a bit strong, but close
I think I just learned something after looking that up.
So WD-40 is 50% something kind of like kerosene and 50% other stuff.
I've used both and consider kerosene to be better for cleaning chains than WD-40.  I keep a small bottle of kerosene around when I'm working on the bike and dip a rag into it to use for chain and sprocket cleaning.  No overspray that way, and it easily dissolves the stuff I want to remove.  If the chain is really bad, I'll dip an old toothbrush into the kerosene and clean about eight inches at a time.  It leaves my chain shiny clean afterwards.
hiero
Quote from: ScottRNelson on May 15, 2008, 03:46:30 PM
[thumbsup]  i get down with the toothbrush too
2000 Monster 750
1999 748
YELLOW!!
CRASH!
Motorex Strong (supposed to be longer lasting than the race formulation)
It seems to be pretty much a wax. I get some fling, but not too bad if I apply on a warm chain then wipe down.
I like the fact that I could buy a tiny spray can that I can refill from the big ones ;D Always have several applications in my tank bag without having to buy a stupid expensive little bottle all the time.
Must say I'm tempted to try the Dupont Teflon though...
Cleaning the outside of your chain with WD-40 on a rag is fine.  Dowsing it with WD-40, not so fine.  The WD-40 can get past the O rings and dilute the permanent lube.  Unless my chain is absolutely disgusting I use chain lube as the cleaner.  I find less fling with this method.
Augustus
I use whatever I can find.  I'm not too concerned though, I don't see it as a problem if I have to replace the chain a few thousand miles earlier if at all.   The one thing I don't like is the white looking lube, something just doesn't seem right about it.
scott_araujo
I hate the white stuff too, looks like gooky spider webs all over the chain.  A local dealer uses this and it's caked all over every chain of every use bike in the showroom.  Guys, excess lube on the outside plates does not extend chain life, it just collects dirt!  I guess it makes it look like the bike has been serviced.
Scott
FireInTheHole
I've used Finish Line Citrus Degreaser for all my bicycles and motorbikes but never on a motorbike chain so I am not sure if it will get inside the inner rings.  What I do know is that it is amazing stuff...a little pricey but not bad for the environment and smells delicious.  We use to have a parts cleaner full of it.  It rinses away with water too!
http://www.finishlineusa.com/products/citrus-cleaner.htm
2006 S2R 800
Austin, TX
Capo
Capo de tuti capi
m1moto
Dupont Teflon Multipurpose lubricant. 7,000 miles and no hassles
2006 S2R1K  |  Red + White  |  Full Carbon Arrows
http://freshbrand.com/
Hollywood
First motorcycle, first chain care product, Castrol Chain Wax.
It works fine as far as I can tell. Being that it is the only one I've ever used. Very little fling.
I've wanted to try the Dupont Teflon lubricant since I first read about it. It will be my next chain lube.
Now to find a product to clean the chain. Why is it, that there are lots of chain lubes out there but hardly any chain cleaners?
R.I.P. Black 07 S2R 800 w/ Speedy Moto frame sliders, CF hugger, Nichols Oil Breather and Arc Fabrication unbaffled slip-ons.
CA Army National Guard, Operation Iraqi Freedom, 2003-2004.
DucHockey
I use the Motul chain lube, and it gets fling everywhere.  I'm definitely switching to something else.
I want to try the Dupont, but I also want something I can stick in my tank bag, so I may go with the Maxima wax.  Does anyone know if there is a consequence to switching back and forth?
2005 M1000s Red
Ddan
Quote from: DucHockey on May 17, 2008, 09:35:31 AM
No FHE, but I'd be surprised if the wax would stay on an oiled chain.
