outside the box
Started by Grampa, February 28, 2009, 09:18:56 AM
lauramonster
Pretty cool!!!
Wonder what the maintenance issues will be??
guess you'd have to slide it often enough so the animals don't nest in it.
Frickin' snow!
Got Duc
erkishhorde
No way you'd get someone doing that in the states.
Quote from: erkishhorde on March 01, 2009, 08:17:01 AM
+1
Every now and then, but these crazy houses always seem to originate from new zee-land
erkishhorde
Well, part of the reason that you don't see a lot of fancy stuff here in the states is geography. West coast gets quakes and a house like that one would be difficult to brace laterally. I'm thinking moment-frame type construction for that and people just plain don't put moment frames in houses.  [roll] Pardon my stereotypes but I don't think Central US-types are the kinda peeps that go for the fancy stuff like that. Plus some areas have tornado concerns.
It would suck to stick your hand out a door or window while it was sliding.
It looks pretty sturdy to me.  In the midwest, the biggest concern would be insulation - doesn't look very tight or warm for the 6 months we run our furnace.
We don't really build for tornadoes though (except a basement)- if you are in the wrong place for a strong tornado then even a block construction building won't stay standing.
Got Duc
Wonder if it has a wlanut craker option?  ;D
sert duc
Here are some cool pictures of it:
The rest can be found here: http://www.dezeen.com/2009/01/19/sliding-house-by-drmm-2/
You may run the risks, my friend, but I do the cutting. We cut down my percentage---uh, cigar?---liable to interfere with my aim.
The final measure of any rider's skill is the inverse ratio of his preferred Traveling Speed to the number of bad scars on his body.
Sleeper_I
^^^  [bacon]
I like the garage  ;D
Just don't hang any picture frame on the outer wall  :P
jdubbs32584
Fresh Pants
Umm... I like that.
For a second I thought BP visited the sliding house. But then realized #1, house is in the UK. #2 BP probably didn't ride across the US, then the Atlantic to the UK. #3 the 1098 is red.   [laugh]
Bwooooooahhh
Braaaaaaaappp
Quote from: Fresh Pants on March 01, 2009, 03:50:35 PM
Umm... I like that.
elementary my dear fresh pants
Manny
Right. My friends custom built their house and put a car lift into the garage. It's a big open elevator which you drive a car into and then lower it into the basement, leaving the top of the lift as a surface to park another car on. The building inspector almost didn't allow them to activate it because he was afraid of the dangers. He ended up making all sorts of safety switches to make it "safer" like the garage door much be closed, the door from the house to the garage must be closed, and the lift takes about 20 minutes to go down or up. Cool device that was so shackled by regulations that it is almost never used now.
That house is very cool, though. From the description (before I saw the video, obviously) I thought the walls retracted into the ground.
