January 10, 2025, 12:43:13 AM
Motors and Frames...
Topic: Motors and Frames... (Read 1501 times)
corey
'06 Tang/Black S2R800
March 04, 2009, 09:13:34 AM »
Well... For possible future projects, i've decided to look into what motors i can fit in my 2006 S2R 800 frame.
Anybody have any info/sources for info?
herm
Re: Motors and Frames...
March 04, 2009, 05:05:53 PM »
in the blind here, but isnt it the frame the same on the s2r1k?
March 04, 2009, 05:14:06 PM »
An S2R1000 engine would fit, but you would need some of the other stuff too, exhaust headpipes, battery tray and bracket, ignition coils, etc.
Not at all sure that the 800 ECU could run the 1000's coils, and the maps wouldn't be optimum.
Not sure if the oil cooler would fit, and also not sure if the midpipe/udder is the same either.
dbran1949
2007 S4RS Black Termis
March 04, 2009, 06:01:53 PM »
For starters the 800 did not have / need O2 sensor (I think in 2006 it was under the EU displacement limit) so The ECU should be open loop
corey
March 04, 2009, 06:13:36 PM »
right right, i assumed it would be more than just motor. i figured if i was going to the 1000 i would need to do at LEAST motor, ecu, & gauges. what about s4 motors? anyone?
