February 08, 2025, 12:46:22 PM *
Pages: [1] 2   Go Down
Author Topic: Call out to Jukie and her Sato rear set  (Read 2469 times)
The Don
« on: March 05, 2009, 11:19:14 AM »
Jukie would you post some pictures of your Sato rear sets, and could you get a close up of your brake side please. Did you and or Betty fit them or did you get your mechanic to fit them? thanks in advance.
Don
Wise men talk because they have something to say; fools talk because they have to say something. - Plato
Jukie
I need a
Paradise
« Reply #1 on: March 05, 2009, 12:15:29 PM »
Hey Don,
here are some pics, if thet are not good enough ill get some more
anything to help my fellow DMF guy
Before Honda CB125N
          Suzuki GS125
Now.   Ducati 620ie
          Lambretta Li150
          Ducati S4RT
Big T
Bikeless..........
« Reply #2 on: March 05, 2009, 12:15:42 PM »
Here you go Don...... From one of the DMF rides....  [moto]
   .... This is your captain speaking. Please fasten your seat-belts as we prepare for take off.... (I'm the passenger now....)
Big T
Bikeless..........
« Reply #3 on: March 05, 2009, 12:16:37 PM »
Just got in front of me Jukie..... Your just tooooo quick.....  Grin
Jukie
I need a
Paradise
« Reply #4 on: March 05, 2009, 12:16:52 PM »
sorry Trev i beat you to it
Before Honda CB125N
          Suzuki GS125
Now.   Ducati 620ie
          Lambretta Li150
          Ducati S4RT
Betty
« Reply #5 on: March 05, 2009, 01:27:03 PM »
... and to answer his question ...
They were installed with the exhausts ... those sexy stainless brackets were custom made to suit, so it was all done at the same time (not by us).
I certainly didn't install them but Jukie has fiddled with the setup since, but more on the gear-change side I think.
The Don
« Reply #6 on: March 05, 2009, 10:51:39 PM »
Thanks for your help Jukie, Betty and Trev, just one more thing, is that a pressure switch on top of your brake slave cylinder, the reason I ask is I bought a set of Lucas adjustable rear sets. To hook up the brake light I have a pressure switch instead of using the original system. If you have a pressure switch I was wondering how you /your mechanic hooked it up.
Don
Jukie
I need a
Paradise
« Reply #7 on: March 06, 2009, 02:10:39 AM »
Hey Don
 i have no idea but the brake lights work so, im assuming it must have been the mechanic that did it. Sorry im not much help. iam a girl after all.  Roll Eyes
Before Honda CB125N
          Suzuki GS125
Now.   Ducati 620ie
          Lambretta Li150
          Ducati S4RT
dragonworld.
I can make like a tripod with my.....
« Reply #8 on: March 06, 2009, 06:10:21 PM »
If its a pressure switch its an easy deal !!  Grin
Usually you just have to get 2 terminals for the switch, (usually standard auto spade types)
and either get a compatible connector for the original loom, or just cut the wires and connect a terminal to each one and then push a wired connector onto each terminal of the pressure switch and away you go!  waytogo
But its dead simple just to use your original, just find a place to anchor the small return spring to the brake pedal. Wink
The Don
« Reply #9 on: March 06, 2009, 06:35:57 PM »
Off the top of your head would you know if the original connector used is a part I should be able to get from a auto electrician, or would I need to go  either to a wrecker or someone like Fraser's.
Don
dragonworld.
« Reply #10 on: March 07, 2009, 05:09:56 PM »
Don
99% of the pressure switches that I have seen have the standard size push on auto spade terminals, available pretty well anywhere. SuperCheap, Repco, Autopro.  waytogo
The Don
« Reply #11 on: March 08, 2009, 12:49:28 AM »
Thanks for your help, Ill check out supercheap tommorrow.
Don
monsta
Perth, Australia.
« Reply #12 on: March 10, 2009, 02:06:40 AM »
hey Don..
how'd ya go, did ya get it done yet?
I've also got a set of Lucas and looking the setup of them.
got any pics of the finished job? where's the resovoir *sp* go?
Yellow Meanie
2000 900Sie
« Reply #13 on: March 10, 2009, 02:51:39 AM »
*Off topic:
                  Jukie, where did you get that rear hugger from?
 carry on...
Betty
« Reply #14 on: March 10, 2009, 01:30:51 PM »
*Off topic:
 carry on...
Carbonworld in Germany - had a very good experience with them. The prices on their website usually includes a VAT (18-19%?) which is not applicable to us. Postage is cheap because everything is so light, but the exchange rate is not doing us any favours at the moment.
Pages: [1] 2   Go Up
