September 03, 2024, 12:20:47 PM
Factory Oil Cooler - Powdercoat/paint or leave alone ?
Topic: Factory Oil Cooler - Powdercoat/paint or leave alone ? (Read 2467 times)
ProTeal55
HalfFastChicago.Com
March 07, 2009, 10:19:45 AM »
QUESTION:
In the quest to get the bike looking as black as I can, I need to do something with the factory oil cooler.
Common sense says that powdercoating it might (stress the word might) make the cooler not perform as well as if it weren't coated (with anything). But, if I do have it coated it would nicely blend in with the rest of the bike and not stick out as much as it does currently...
Anyone powdercoat/paint their oil coolers on their scoots ?
And if so, anyone notice an increase in temp because of it ?
As usual, ALL help is greatly appreciated
Member: Half Fast Chicago
Website:
Omnipotent Potentate
Personal Pretext
Re: Factory Oil Cooler - Powdercoat/paint or leave alone ?
March 07, 2009, 10:33:10 AM »
Look up radiator paint.,, but that stuff pretty much only comes in black or silver
Stuff like powder coatings will act as an insulator as you've noted. If you were careful and masked off the cooling fins, only painting/coating the outer body of the cooler, you could probably get away with it, with minimal detriment. But I wouldn't coat the radiator fins
ProTeal55
HalfFastChicago.Com
March 07, 2009, 10:38:59 AM »
Thats kinda what I was thinking.
If I do end up coating it, I will just do the body and leave the fins alone.
Atleast that will help the side profile of the cooler blend in with the rest of the bike better than it does now..
Last Edit: March 07, 2009, 10:53:03 AM by ProTeal55
Website:
TAftonomos
is without a monster :(
March 07, 2009, 12:07:45 PM »
somewhere in my project thread there are pics of what and how I did it.
MyDucParts.com
March 07, 2009, 01:16:05 PM »
radiator paint is the way to go. clean scuff spray dry wait!
Oldfisti
My mom says I'm a catch.
March 07, 2009, 01:50:52 PM »
Quote from: He Man on March 07, 2009, 01:16:05 PM
+1
It's formulated not to affect thermal transfer.
ProTeal55
HalfFastChicago.Com
March 07, 2009, 02:32:16 PM »
10-4
Ordered some up from Eastwood- thanks guys
Website:
DucatiBastard
"Apollonia" '06 S2R 800
March 07, 2009, 05:37:12 PM »
Kinda off topic but in my meandering thoughts about when I tear down my bike and wildly customize it, i think it'd be cool to rotate the oil cooler so that its vertical, maybe move it back between the frame tubes, a la the new Honda Fury chopper. I think this, combined with the paint would make the cooler almost disappear. IDK, just thinkin'
Give a man a beer, and he wastes an hour.
Teach a man to brew, and he wastes a lifetime.
2006 Ducati S2R 800, 2004 Honda Dream 50R, 2001 Kawasaki W650, 1940 BSA M20
ProTeal55
HalfFastChicago.Com
March 08, 2009, 07:32:39 AM »
I def. thought about mounting the cooler vertical rather than in it's stock position.
I would def. "flow" better with the rest of the motor/frame/etc..
Once I get into that part of the project I will see what's all involved, and if it isnt like re-inventing the wheel I will
prob. do it..
Website:
March 08, 2009, 08:24:20 AM »
I used VHT hi-temp engine paint in the past on the SS2R project and it worked just fine. As long as you're not giving it many coats (I did two thin coats BTW), it won't really affect heat transfer. P'coating it would be like wrapping it in a blanket though (IMO).
Post up some pics when it's done! I'd like to see how it comes out.
BTW, there are a few Duc's out there with the oil coolers relocated to different positions... Could be good!
March 08, 2009, 08:31:13 AM »
All the radiator paint I've used has been nasty stuff that always stays kinda sticky.
Anyone have a link to the eastwood stuff?
TAftonomos
March 08, 2009, 09:35:55 AM »
oh comeon now, ever GW Bush can use the google
http://www.eastwoodco.com/shopping/product/detailmain.jsp?itemID=125&itemType=PRODUCT&iMainCat=390&iSubCat=391&iProductID=125
Also, and probably not needed... I cleaned the cooler with brake cleaner, then sanded the tanks down with scotchbrite (red stuff). Recleaned again and wiped it with a tack rag.
I then masked off the fins and painted the end tanks with a spray bomb epoxy paint designed for engine blocks. After 3-4 coats, I painted the fins with the eastwood stuff. There was a slight difference in the finish, so I applied one more coat to the entire thing.
So far, after about 3K worth of riding, no chips on either the cooler or radiator.
Probably don't need to do the epoxy paint on the tanks, but it hasn't seemed to hurt anything either.
Both the epoxy and the eastwood rad paint dried fairly quickly.....iirc it was around 80 deg when I painted.
Last Edit: March 08, 2009, 09:45:28 AM by TAftonomos
MyDucParts.com
March 08, 2009, 09:47:18 AM »
Quote from: TAftonomos on March 08, 2009, 09:35:55 AM
I would have if I really cared.
ProTeal55
HalfFastChicago.Com
March 08, 2009, 05:47:54 PM »
I will def. post up some pics of the final project.
I am pretty much tearing my whole bike apart to do little things here and their I have been wanting too since I brought it home from the dealer.
I have a build thread going on over at the Half Fast Chicago forum (see below if you want/care):
http://www.halffastchicago.com/forum/index.php?topic=450.0
I will update it as much as I can as progress begins to be made on the project...
Website:
Goat_Herder
Reply #14 on:
April 29, 2009, 12:29:58 PM »
Quote from: ProTeal55 on March 08, 2009, 05:47:54 PM
Any update on the painted oil cooler? Some have suggested turning the cooler vertical, too.
Goat Herder (Tony)
2003 Ducati Monster 620 - Yellow
SOLD
2007 Ducati Monster S2R1000 - Black
KILLED
