January 10, 2025, 05:09:35 AM *
Pages: 1 [2] 3   Go Down
Author Topic: Open Dry Clutch - Sound seems, uh, unhealthy.  (Read 7408 times)
bryan8494
« Reply #15 on: March 08, 2009, 11:11:56 AM »
for really?? damn it....hey how difficult is it to rewire the crap attached on boths side under the seat of the monster 695?  anyone got diagrams that would be cool...thanks again
« Reply #16 on: March 08, 2009, 12:10:45 PM »
For REAL for real.
You mean the stuff under the side panels? Its not hard. Its just a matter of finding places to put them. Of course, then you're left with the brackets and stuff.
Omnipotent Potentate
Personal Pretext
« Reply #17 on: March 08, 2009, 01:32:33 PM »
Thanks again for all the responses.
Kevin
I spy with my little eye reflectors!  Give 'em the chop.
To the best of my knowledge, the 695 has a wet multiplate system.
That is correct.  Any Monster below 900cc will be a wet clutch.
Mike_D
« Reply #18 on: March 08, 2009, 02:57:26 PM »
That's a nice looking S2R you have there Kevin.  Thanks for posting the pic.
2008 S2R 1k.  Black.  Pazzo Levers, 14 t front sprocket, CRG Hindsight LS mirrors, Cycle Cat Frame Sliders,  Oberon open clutch cover and gold/black EVR pressure plate, full Arrow exhaust with reflashed and mapped ECU, tail chop with gold Rizoma Avio 21 turn signals, Ohlins rear shock and Rizoma fluid reservoirs.
Mojo S2R
. Dark Mojo .
« Reply #19 on: March 08, 2009, 08:40:00 PM »
nice pic...i'm thinking to do the same for my monster 695.  a quick question, for now could i take off the black plastic covers that cover the clutch on each side?  thanks.
The 695 is a wet clutch.  Can't run it without clutch cover.  I'm guessing that you are talking about the timing belt covers.  Their plastic.  The clutch cover is metal.  A lot of people run their bikes without timing belt covers or with open covers.
bryan8494
« Reply #20 on: March 09, 2009, 04:48:22 AM »
Yep, it's the thin layer of black plastic on both sides, i can remove them right?
Personal Pretext
« Reply #21 on: March 09, 2009, 05:22:47 AM »
No.  There is no thin black plastic on both sides.  Perhaps you're mistaking the powder coating used on the clutch and alternator covers for plastic.  On a stock 695 you cannot expose any of the clutch works and run the engine w/o be very very unhappy you did.
The only plastic bit in that area you could safely remove is the cam belt covers.  They are the 2 -part covers in an L configuration.  They are on the right side of the bike.
kfmarshall
Properly cared for, it will always look like a
2007 Silver S2R1000
« Reply #22 on: March 09, 2009, 06:15:17 AM »
Thanks yuu, I will do so immediately.
Personal Pretext
« Reply #23 on: March 09, 2009, 07:11:59 AM »
NP - just saving you from the reflector ragging that goes on here.  If you want the ugly yellow plastics off, but still want somethign reflective TapeWorks makes reflective wheel tapes in all sorts of colors
http://www.tapeworks.com/Rimstripes/RimstripesHome.html
Smokescreen
« Reply #24 on: March 09, 2009, 10:05:34 AM »
i'm not positive how mechanically inclined you are, but I've heard reports of wet clutch owners converting by replacing the clutch side case cover with an M900 cover and replacing the wet clutch assembly with a dry clutch assembly.
The benefits are, you get a dry clutch rattle!! yay!
The drawbacks are, you get a dry clutch, that's harder to modulate, has a harder lever pull, wears out faster, and therefor costs more...  Even after the roughly $1000 you'd be spending buying a used right hand case cover, all new seals on that side, and new clutch assembly.
So......  You might want to stick to set clutchness.  Ducati thinks it's a better idea.  the 848 has a wet clutch now, as does the Multi1K.
I THINK there is an aftermarket clutch-side case cover that has some kind of clear plastic where the clutch is so you can see it spinning round and tossing oil everywhere, if that interests you.  Wouldn't be any louder, but it'd be pretty!
Catching a yellow-jacket in your shirt at seventy miles per hour can double your vocabulary.
Only a biker knows why a dog sticks his head out of a car window.
Personal Pretext
« Reply #25 on: March 09, 2009, 10:15:34 AM »
Yeah - it is possible to work over a wet clutch monster into a dry one.  But smokescreen's right - it's costy.  There's a large expense for parts and possible even more for labor.  It isn't just a straight swap - pull off the old, put on the new.  There need for some modifications and machining.  People have done it.. but the price is equal to a pretty good down payment on your next bike
I've seen clutch covers for wet clutch Jap bikes that have that window... but I don't think I've spotted one for Ducs so far.
bryan8494
« Reply #26 on: March 09, 2009, 11:30:52 AM »
thanks smoke!
greenmonster
« Reply #27 on: March 09, 2009, 02:32:12 PM »
Another (boring, ) fact:
Original clutch cover can take a 70 km/h lowsider w/o damage to clutch.
« Last Edit: March 09, 2009, 05:02:46 PM by greenmonster » Logged
M900 -97
MTS 1100s  -07
bryan8494
« Reply #28 on: March 09, 2009, 05:13:54 PM »
just to make sure we're talking about the same thing....below is the link to a 695, so i can't take the black covering panel over the clutch off??
http://www.totalmotorcycle.com/photos/2007models/2007-Ducati-Monster695d.jpg
alexisonfire
« Reply #29 on: March 09, 2009, 05:25:13 PM »
I'm not sure you know where or what the clutch is period.  My advice is not to touch anything.  Get a half competent individual to show and explain these things to you in person.  I'm sure there are Ducati / motorcycle meets in your area.  Maybe a board member will mark up a picture or provide you with an explosion view diagram.
You can live to 100 if you give up all the things that make you want to live to 100.
07 S2R 1000
Pages: 1 [2] 3   Go Up
