January 10, 2025, 05:27:58 AM *
News: Please Help
Author Topic: Trimming Body work  (Read 1349 times)
killerniceguy
« on: March 08, 2009, 11:58:47 AM »
I have picked up some sharkskinz body work for my monster and need to trim it to get a good fit.  Can anybody give me advice on the best way to do this.  I have limited experience with fiberglass.
KNG
S2R800 race bike.  www.ducaticup.com
Spidey
Crashin' mofo
« Reply #1 on: March 08, 2009, 12:01:17 PM »
I've always just used a dremel to trim bodywork.  Measure twice, cut once.  Make sure you wear a mask and long sleeves.  That fiberglass dust itches like hell.
toaster
« Reply #2 on: March 10, 2009, 08:32:13 AM »
and wash up with the hottest water you can stand
Mash
« Reply #3 on: March 10, 2009, 01:46:59 PM »
I used to work in the boat building industry spraying a chopper gun all day.  My experience was that cold water didn't open up the skin pores and let the fiberglass into your skin.  A hot shower after work, and I'd be itching all evening.  Of course, YMMV.
'06 S2R1000
toaster
« Reply #4 on: March 11, 2009, 12:33:23 PM »
i remember it differently, but then again im always doing bodywork outside in texas summer heat.  the cold water would make me itch more than ever, but hot water seemed to do the trick.
btw, what does "ymmv" mean?
Spidey
Crashin' mofo
« Reply #5 on: March 11, 2009, 01:59:01 PM »
That one took me four-yever to figure out.  It's means "Your Mileage May Vary."  More explanation about it and other DMF terms can be found here:
http://ducatimonsterforum.org/index.php?topic=10432.0
I've always done cold water cuz I assumed --like Mash-that hot water would make it itch more.  But like Mash also said, YMMV.    Grin
« Last Edit: March 11, 2009, 02:00:58 PM by Spidey » Logged
teddy037.2
« Reply #6 on: March 12, 2009, 01:11:30 PM »
hot water always worked for me, too...  Cheesy
PPE is the main thing, like spidey said. respirator, sleeves, and I would wear latex or nitryl gloves, too.  but then all the fiberglass work I've ever done was fixing stuff on cars, so the gloves made for easy cleanup what w/the resin and all.
dremel sanding drums are awesome!
Norm
hurricanemotorcycles.com
« Reply #7 on: March 12, 2009, 11:16:48 PM »
Chopper gunning ALL DAY!! Cry You must be some kinda masocist!! bang head
I use a die grinder for cutting most fiberglass, but motorcycle fairings are pretty thin and you can probably use most anything that will leave a clean line. Use masking tape to cut against.
needtorque
« Reply #8 on: March 13, 2009, 04:07:55 AM »
Try the icy/hot shower.  All cold 1st to rinse of the stuff on top then switch to hot to open pores and clean out anything that got in there already.
Who insures the FDIC?
