February 23, 2025, 05:19:27 PM *
News: Please Help
Pages: [1] 2   Go Down
Author Topic: New Ducati Motor?  (Read 1944 times)
Giannis
Bad Brains
« on: March 08, 2009, 01:40:09 PM »
http://www.motociclismo.it/Edisport/moto/GalleryR2.nsf/foto-moto/Tecnica-motore-CGM-Ducati-01
No Desmo, Bevel Driven How about that?  popcorn
« Last Edit: March 08, 2009, 07:43:43 PM by Giannis » Logged
Billy: We did it, man. We did it, we did it. We're rich, man. We're retirin' in Florida now, mister....
Captain America: You know Billy, we blew it....
www.speedjunkies.gr
Duc L'Smart
« Reply #1 on: March 08, 2009, 02:58:52 PM »
Kinda cool looking...
'07 1098s, '06 Paul Smart LE, '99 BMW K1200RS, '73 BMW R75/5, '67 Ducati Monza 250 Bevel Drive, '63 Vespa GS 160
Cher
Mostly Harmless
« Reply #2 on: March 08, 2009, 03:15:00 PM »
It's interesting, definitely.  Were the earlier bevelheads more maintenance or less than the current belt-driven cam arrangement?
« Last Edit: March 08, 2009, 03:20:20 PM by Cher » Logged
fastwin
« Reply #3 on: March 08, 2009, 03:41:11 PM »
Bevel drive = no more expensive cam drive belts to replace. In this day and age of Harleys being belt driven why can't Ducati make cam drive belts that do not need to be replaced every two years?? Me thinks I smell planned obsolescence... the plot thickens. Roll Eyes
Besides, you can put the cool old see through sight glass pieces on the heads of the bevel drive motors and watch stuff spin around! applause popcorn bacon
Pinocchio
Unsung
« Reply #4 on: March 08, 2009, 05:34:30 PM »
Looks like an efficient way to power a SOHC valvetrain to me. It would be great if the engineer could figure how to produce it as cheaply as a Pantah-head. I wonder if they are considering a desmoquattro?
1969 Scrambler (450 “Jupiter”), 2005 MTS 1000DS, 2007 Monster S4RS, 2010 MTS 1200S Touring, 2018 Monster 1200R, 2021 Monster 937+
GeorgeInDallas
« Reply #5 on: March 08, 2009, 05:41:28 PM »
I'm witchoo, man.  < Maintenance =  waytogoapplause .  In their 4-cyl engines, Toyata dropped the timing belt in favor of a (maintenance-free) timing chain.  Y'know, if the belt saves 1 lb over the chain, I'd take the chain and be happy to keep the money spent on maintenance.
George
"It's about the ride.", Peter Fonda in Wild Hogs.
calscrazy
« Reply #6 on: March 08, 2009, 06:07:07 PM »
every 2 years my arse. how about every 15k which is 14-18mos.
home will always be between the red and rio!!!
2007 m695 errr recently passed away
Cher
Mostly Harmless
« Reply #7 on: March 08, 2009, 06:48:48 PM »
O.K., let me just start out by saying I'm NOT pregnant doging (not there's anything wrong with that)  BUT...
Is there a more expensive 4-stroke motorcycle motor to maintain than a Ducati?  Seriously.  Out of all the other motorcycle motors currently being manufactured, is there anything else out there that rivals the cost-per-mile to haul itself down the road compared to a Duc?  I honestly don't know but I suspect that with the exception of maybe  a Bimota, a 4 valve L-Twin Desmo wins that dubious distinction.
So! "new" bevelhead?  Bring it!  This is probably as good a time as any for Ducati to pull an otherwise excellent motor up to more acceptable standards for routine maintenance.
« Last Edit: March 08, 2009, 06:54:30 PM by Cher » Logged
RichD
« Reply #8 on: March 08, 2009, 08:15:39 PM »
I have heard the belts are going away... and "gear drive" is coming (bevel?).
But the engine case in the display picture is not what I understand will be the new design...  Grin
-and the intake *as pictured* will simply not work!
Oh, there is something else "new" for the new motor that has not even been mentioned yet  Cool
 popcorn
DFW-MFer!
Duc L'Smart
« Reply #9 on: March 08, 2009, 08:28:17 PM »
Flux Capacitor?
Hyper Drive??
RichD
« Reply #10 on: March 09, 2009, 03:28:24 AM »
Flux Capacitor?
Hyper Drive??
Close, Mr. L'Smart, very close...
"Plain" (shell-insert type) engine bearings.
You know, like the ones in just about every other engine on the planet.
Which would require: A horizontally split crank-case -not a vertical split case like we have now
(the above picture shows no parting line/fasteners to facilitate a horizontal split)
Which, of course, would require a new design high-pressure oil system...
You'd toast bearings very quickly with the oil delivered the current system provides.
(roller main bearings can run with oil delivery "interuptions" -plain bearings start to go up in smoke almost instantly)
Roller bearings are used on the crankshaft mains now.
Very low rolling friction once set up correctly -a nice benefit.
But: They can withstand only "so much" hammering before failure.
They are heavy.  They cost (much) more.
The machine work required to use them is hugely more complicated than plain bearings.
And you have to shim the crank for proper preload precisely to make them work...
That takes time, which equals money.  $$$
We'll save:
Time.  Money.  Weight.
Oh and we'll get better oil delivery too!   waytogo
DFW-MFer!
hiero
« Reply #11 on: March 09, 2009, 07:24:46 AM »
hey now, I think my cost of ownership's not so bad at all!
2000 Monster 750
1999 748
YELLOW!!
Cher
Mostly Harmless
« Reply #12 on: March 09, 2009, 09:28:44 AM »
We'll save:
O.K. so ditch the roller bearings and use brass shells - just like the D16GP6.  Makes sense (and 'cents'!) but when you say, "high pressure" oil system, I think of dry sump motors with a remote oil tank (Corvette LS7 for example).
Wassup with that?  Remote oil tank somewhere on the new Ducati or is that too car-y?  laughingdp
I do like the idea of gear driven cams (bevel drive or "traditional" gears, like the RC51) as that ultimately could/should mean less maintenance; it's also the technology used on all the GP machines if I'm not mistaken for the last quarter century.  But if I play devil's advocate on this, I don't see the dealers just rolling over on the less maintenance idea - service has got to be their bread and butter.  My point is, to keep their dealer network viable, would a meaningful reduction in routine service cost be in Ducati's best interest long-term?  Maybe it won't be in cam belt replacement but the cost to play is  bound to be up somewhere.
And if they're re-thinking their approach to engines in light of contemporary technologies, what about traditional valve springs?  Total heresy, I know  Evil
Hell, if Ducati wanted to go really berserk, they could add "high-pressure" (pneumatic) valves to the list...
« Last Edit: March 09, 2009, 09:33:12 AM by Cher » Logged
hiero
« Reply #13 on: March 09, 2009, 09:55:45 AM »
if I'm not mistaken, the old bevel drive heads required more frequent maintenance than the belt drive of today, that may speak more to the state of the technology in those times rather than the actual tech, but just saying
2000 Monster 750
1999 748
YELLOW!!
Cher
Mostly Harmless
« Reply #14 on: March 09, 2009, 10:45:57 AM »
Not to get totally side tracked but I think you're right... In the late 50's I think Porsche had used bevel drive on one of their flat fours in endurance racing.  Ended up there were only two people on the face of the earth who could get the little gem (a-hem!) to run at all.
Ahhhh-HA! now I'm beginning to see the Ducati angle on all this  Evil  laughingdp
Pages: [1] 2   Go Up
