PCIII Question. I think i may have found a topic not yet discussed!
Started by corey, May 14, 2008, 06:46:44 PM
corey
Well guys. I'm considering doing a custom exhaust on my S2R, following suit with the Hedman Hedders "Hot Tips," some baffles (:(), some Jet-Hot black ceramic coating, and probably a spark header... Obviously with an exhaust this open, there are going to be some air/fuel ratio issues. I was planning on going PC3, but have run into a snag.
I am on a MAC! It doesn't seem like PC3 currently supports Mac OS X.
Anyone out there on a MAC running a power commander, and tuning from their Mac?
Any Ideas?  ???
Monstermash
Good luck with this.
I don't think there are enough Mac users for Dyno Jet to bother making an application.
Honestly. I doubt their software requires much computing. Just borrow a friends Laptop, or ebay a $200 laptop. Hell, windows 98 baby. [thumbsup]
DrDesmo
Quote from: corey on May 14, 2008, 06:46:44 PM
Any Ideas?  ???
- VirtualPC has USB device support if you're running a G4/G5 mac
- If you're running an intel mac, use Boot Camp or Parallels and run Windows on that, they'll both be able to use your USB port  [thumbsup]
-Adam
'95 916
'12 800XC
A.duc.H.duc.
Quote from: DrDesmosedici on May 14, 2008, 08:54:27 PM
-Adam
except parallels and the windowsXP licence cost more than getting an old laptop off ebay as previously suggested.
corey
i've already got a copy of windows ;)
i guess the last question is, does the PCIII work with my bike?
It's a non-o2 sensored 2006 S2R. Does the PCIII have issues with the immobilizer?
hypurone
Quote from: corey on May 15, 2008, 06:26:59 AM
It will work fine with the immobilizer. It doesn't have anything to do with it so no harm there. The trick may be finding a PCIII that is old school (non-EX) or a shop that will install the race ready version (not approved for road use). The new EX prohibits modification to the lower rev ranges of the map to comply with the huge fine/citation Power Commander got from the EPA. I believe you will need the following unit as they don't list one exactly for your bike, 717-411. This is the one I used on my S4RS (Full Termi sys already installed so no O2).
The S4Rs and the S2R800 may not use the same injectors, so the connectors may be different.
hypurone
Quote from: Speeddog on May 15, 2008, 10:24:21 AM
Well that part number is actually for an M1000s.i.e so something tells me it should....
Qfactor
