January 10, 2025, 05:31:32 AM
Front Turn signals Options
Topic: Front Turn signals Options (Read 2706 times)
DucLeone
March 09, 2009, 07:08:23 PM »
what are my options?
i don't really like the stock ones, I've seen the rizoma selection, and I'm not sure about them.
i want to keep my fairing on, so i have to make sure they stick out far enough to clear it, or has anyone tried to install signals on the fairing (flush mounted)?
wonder how it would look and funktion (would they be to close to the head light)
please post some pics to show your setup
Thanks
Oni
DUCATI NON E UNA MOTO, E UN STILE DI VIVERE
KISS FRENCH AND RIDE ITALIAN
S2R 800 Black
needtorque
Re: Front Turn signals Options
March 09, 2009, 07:21:09 PM »
This is a picture of mine. You can see the signals but mine is sans fairing so probably not much help. They are very bright though.
Who insures the FDIC?
asado
March 09, 2009, 09:09:43 PM »
Rizoma zero-11 from Pj'sparts
Last Edit: March 09, 2009, 09:51:08 PM by asado
March 10, 2009, 06:04:53 AM »
Quote from: asado on March 09, 2009, 09:09:43 PM
holy crap. is that your bike? you need to put that up for BoMB
Mduc
March 10, 2009, 06:48:37 AM »
I purchased some Rizoma's from PJs for the back. I was thinking of doing the same to the front but then decided to order the DP Performance mirrors with intergrated LED signals in them as I am not a big fan of bar end mirrors.
Rizoma has extenders that work with all their blinkers. So if you need them further out its not really a problem. The extenders come in black or silver to match whatever you are doing and PJs has them in both finishes.
07 S2R1K
DucLeone
March 10, 2009, 07:27:05 AM »
Quote from: Raux on March 10, 2009, 06:04:53 AM
+1
that thing is sweet
did you have any problem with the back ones ,as far as clearing the seat cowl, i installed some mini led on the back and had to bend the mount downward so they wouldn't touch the cowl.
S2R 800 Black
Omnipotent Potentate
Personal Pretext
March 10, 2009, 07:42:56 AM »
Quote from: DucLeone on March 09, 2009, 07:08:23 PM
Thanks
Oni
I've got Rizoma Zeros all the way around. Up front the fairing covers about 50% of the signal if they are in the stock mounting. Also, if they are in the stock position, you have to figure out a different solution for that rubber bumper that the fairing mounts to. I simply drilled new mounting holes further down the headlight mounts. That 1) Dropped the signals below the fairing so they are no obscured 2) Let me use the stock shoulder bolt and a nut to mount that rubber fairing mount as opposed to the bodged up version I had w/ the Zeros in the stock spot.
RE: FLush mounting. I did that on my tail end. I've got a Shift-Tech 1/2 tail w/ the Zeros flush mounted to it. To do that, you have to cut the support stalks of the zeros down to about 1/2" (Mind you this is the 1st gen of Zeros w/o the flex stalks)
asado
March 10, 2009, 07:53:00 AM »
Quote from: DucLeone on March 10, 2009, 07:27:05 AM
+1
that thing is sweet
Thank you. I purchased the Rizoma extender to clear the rear cowl.
DucatiTorrey
My wife's super hero is my
Industrial Designer
March 10, 2009, 08:53:27 AM »
Is that Raux's bike? anyways, looks sick
Thinking of doing something like this to the 69-6
- real place
March 10, 2009, 11:15:26 AM »
Quote from: ducatitorrey on March 10, 2009, 08:53:27 AM
No, that's Asado's. i have a white 696.
DucatiTorrey
Industrial Designer
March 10, 2009, 11:37:48 AM »
Quote from: Raux on March 10, 2009, 11:15:26 AM
h athats what i thought
- real place
Mash
March 10, 2009, 12:54:29 PM »
I'm using the Rizoma Avio-21 signals on all 4 corners of my bike. I used the extensions on the front to get them out past the fairing. The rear ones didn't need the spacers. They're not quite the same red as the Duc, but close enough for me. (I can take more/better shots if you're interested, just let me know.)
here's what they look like in the back (without spacers)
Last Edit: March 10, 2009, 01:28:31 PM by Mash
'06 S2R1000
Mojo S2R
. Dark Mojo .
March 11, 2009, 12:16:50 AM »
I got the Super 29 LED Signals from Luckybike Accessories on ebay for $30 (
http://myworld.ebay.com/luckybike-accessories/
My bike so far...
My desktop/wallpaper
CCMHA Map
Central Cal Monsters
DucHead
No garage queens
March 11, 2009, 03:39:14 AM »
Kellermann Micro-1000s all around. They're really small, but bright as a make the beast with two backsin' supernova.
Last Edit: March 12, 2009, 03:22:56 AM by pompetta
"45"
kfmarshall
Properly cared for, it will always look like a
2007 Silver S2R1000
Reply #14 on:
March 11, 2009, 06:56:39 PM »
Quote from: asado on March 10, 2009, 07:53:00 AM
Keeping up with this board is a full-time job - so many good ideas, not enough time to absorb and research them all.
But, I will be looking into the Rizomas....
