February 08, 2025, 01:26:14 PM
Please Help
OZ monsters
oil hungry 620i.e
Topic: oil hungry 620i.e (Read 1325 times)
niko.620
oil hungry 620i.e
March 10, 2009, 03:36:14 AM »
Hey all,
Ive done about 2000km's on my 06 monster in the two months ive owned it and have already had to top up the oil (when its level) and its starting to go down again, is this normal for these bikes to be using so much oil. It doesnt blow any smoke, doesnt smell of oil nor are there any leaks, is this normal? If not should i take it back to frasers at concord for warranty?
Cheers.
mattyvas
Re: oil hungry 620i.e
March 10, 2009, 03:45:02 AM »
Hey Niko,
I can't say mine ever really used oil much. How much are you filling up?
Is your oil filter on tight? Don't really know but I'm sure you'd see if there is anything escaping out the bottom.
My new web home is now at
www.mattvas.com.au
MattyVas Flickr Photos
OzMonsters Flickr Photos
goldFiSh
March 10, 2009, 03:48:00 AM »
I've never had to top up my M800 either.. Sorry, I did have it one time, and it was exactly as matty said, the oil filter was not sealing properly. It was characterised by a regular burning smell whilst stopping, where my leak was dripping onto the hot header whilst stopped...
dragonworld.
I can make like a tripod with my.....
March 10, 2009, 01:15:53 PM »
Hmmmm, if it aint burning it or leaking it, it could be high crankcase pressure (Leakage past rings, not seated yet of maybe glazed) pushing the oil (vapour) through the breather system and into the airbox, and back through the engine again??
Pop the top off your airbox and remove the filter and see if there is any oil in there??
plazos
March 10, 2009, 01:35:29 PM »
Howdy Guys
I've recently purchased a 620ie and have completed about 3000kms since my last service.
I'll check my level and get back to you on whether mine doing the same.
cheers
Paul
mattyvas
March 10, 2009, 01:42:09 PM »
G'day Paul,
Good to see another newbie here, add yourself to the introduction thread.
And in the show us your ride thread. Hope you enjoy the 620, I'm just about to get off mine and trade up.
Thread jack over.
Back to using oil issues.
www.mattvas.com.au
niko.620
March 10, 2009, 02:04:23 PM »
just checked the airbox and its free of any oil residue, checked around oil filter and crankcases but cant see any weeping. I think i might give it a oil change and new oil filter this week and take it for a good ride on the weekend and see if it drops down again. If so i might take it back to Fraser's.
Thanks for the help guys much appreciated.
mattyvas
March 10, 2009, 05:32:34 PM »
No problem, let us know you go.
www.mattvas.com.au
Super T.I.B
March 10, 2009, 11:15:57 PM »
Mine was leaking a little oil around the filter. Run a clean rag around it, take it for a run to warm it up, then when you come back and let it sit for 1/2 hour, make sure it's cool enough to touch but run your finger around your filter and see if you have any oil on your finger.
If you have, take it back to Frasers, if not, see first option.
brimo
酒後吐真言
March 10, 2009, 11:25:09 PM »
Quote from: niko.620 on March 10, 2009, 03:36:14 AM
Hey all,
Cheers.
No It's not normal for something only three years old unless it's got alot of Ks on the clock, the only way to properly check if it's burning any ( and it has to be the case if there are no leaks, it just doesn't evaporate in to thin air) is to have someone ride behind you and observe what happens on acceleration and decelleration.
From a story by RAT900
wayne800
March 10, 2009, 11:51:52 PM »
Niko
Have a 6 month old S2R 800 with 7K on it & it hasn't used a drop of oil.
You say its covered by a warranty. My advice is to take it back to the dealer before the warranty expires to get the problem logged.
Once had a car with an oil problem but didn't report it until one month after warranty expiry - guess who paid for the repairs?
Wayne
ducsport
March 11, 2009, 03:37:03 AM »
Niko, my 620 has 10,000 km on it, six years old, and has never used a drop of oil between changes. Take it back to get the issue logged within the warranty period. Cheers, ducsport.
niko.620
March 12, 2009, 04:46:22 PM »
Thanks for your help everyone, im taking it back to frasers (if they return my calls) in the next few days and hopefully i will get to the bottom of it.
brad black
March 13, 2009, 03:38:27 AM »
before you take it anywhere you need to record how much oil it uses (quantity you topped it up with) over a certain number of km (preferably several hundred or more). and be accurate with the numbers. without that info you're wasting your time and theirs.
and be aware some manufacturers have fairly large limits for oil use. you have to use more than a litre per thousand km before bmw consider it excessive.
Brad The Bike Boy
http://www.bikeboy.org
dragonworld.
Reply #14 on:
March 13, 2009, 10:42:15 PM »
Hmmmm, both "old" M750 and the DS dont need topping up at all between services!
