January 25, 2025, 04:04:30 AM *
News: Please Help
Author Topic: Mini rear brake reservoir  (Read 1133 times)
DucHead
No garage queens
« on: March 10, 2009, 09:31:22 AM »
I fabbed a rear brake reservoir from some 1/2" aluminum tubing, extra Rizoma outlets, some o-rings, an M8 aluminum bolt, an adel clamp and some zip ties:
For the outlet, I tapped M7x1.0 threads into the tubing, and for the cap I tapped M8x1.25 threads.  Some Tygon, zip ties, o-rings, adel clamp and viola!
I let it sit overnight and there were no leaks.
If you're careful, you can do the swap without bleeding:
Installed:
Brakes work fine.  The volume of the tubing allows for sufficient amount of fluid, and I left the "reservoir" 2/3 empty to allow for fluid expansion.  This should be fine as I only use the rear brake for low-speed maneuvers, finishing stops and while sitting at traffic signals.
« Reply #1 on: March 10, 2009, 09:36:44 AM »
Hey, you changed the cap/bolt!  Smiley
DucHead
No garage queens
« Reply #2 on: March 10, 2009, 09:42:40 AM »
Wow, nothing gets past you!   Shocked   I found the red one lying around and it was already cut to size.
...and I'll prolly change it again!   Grin
« Last Edit: March 10, 2009, 11:36:57 AM by pompetta » Logged
corey
'06 Tang/Black S2R800
« Reply #3 on: March 10, 2009, 11:33:05 AM »
nicely done! looks very cool!
how much$? Grin
DucHead
No garage queens
« Reply #4 on: March 10, 2009, 11:36:13 AM »
how much$? Grin
$0.  I had all this lying around the garage.
I suppose if you bought everything from Home depot it would run you $10-20, the aluminum tubing being by far the most expensive item.
