January 10, 2025, 05:47:50 AM
4 Valve Billet Coolant Bottle Cap
Topic: 4 Valve Billet Coolant Bottle Cap (Read 3203 times)
phierce
March 10, 2009, 12:45:53 PM »
Anyone found a billet coolant bottle cap for the 4 valvers?
S4R
748
vwboomer
Re: 4 Valve Billet Coolant Bottle Cap
March 11, 2009, 08:06:05 AM »
Ok I'll ask. Why?
2005 S4R - Sato, PM, CC, Sargeant
2005 GasGas FSE450
2004 Honda VFR
DucHead
No garage queens
March 11, 2009, 08:13:09 AM »
Quote from: vwboomer on March 11, 2009, 08:06:05 AM
Ok I'll ask. Why?
Well, I can't answer this question, but I do wish I could re-locate the overflow bottle without removing the airbox.
On the other hand, a less hideous overflow bottle would be nice too.
"45"
phierce
March 11, 2009, 08:39:04 AM »
Ok I'll ask. Why?
Bling, why else?
S4R
748
Bill in OKC
S4Rs
March 11, 2009, 02:23:35 PM »
Quote from: pompetta on March 11, 2009, 08:13:09 AM
I think you can go to a MUCH smaller container if you keep an eye on it. I relocated my overflow tank and have been watching the coolant level. It does not expand nearly as much as the stock tank allows for. I've been looking for an even smaller tank - and the one I have is maybe half as large as the stocker. It barely fills up the hose, let alone filling the tank... it is not summer yet but I've seen high 180s on the temp gauge.
'07 S4Rs '02 RSVR '75 GT550 '13 FXSB '74 H1E '71 CB750
DucHead
No garage queens
March 11, 2009, 04:10:24 PM »
Quote from: Bill in OKC on March 11, 2009, 02:23:35 PM
From where did you get your container?
To my knowledge, my overflow bottle was put to use
once
-- when I underfilled the radiator.
"45"
vwboomer
March 11, 2009, 08:31:20 PM »
Quote from: phierce on March 11, 2009, 08:39:04 AM
Bling, why else?
Oh. Yeah I don't get that.
But as noted, a smaller bottle would be nice. Makes it lighter (tiny bit). Makes it look cleaner. I get those things
2005 GasGas FSE450
2004 Honda VFR
Bill in OKC
S4Rs
March 11, 2009, 08:34:46 PM »
I'm using a black/black one of these for the time being
http://www.advancedperformanceaccessories.com
->product overview -> coolant tank system
Motion pro makes a nicer one with a screw top but it is larger
http://www.motionpro.com/motorcycle/partno/11-0025
I found a small square HRC tank on ebay but it just doesn't fit in anywhere .
So far the black one works for me. There is no lid on it to unscrew so it is empty when the bike starts, catches whatever pushes past the cap and returns it as the bike cools down. I've never seen it get high enough to show in the sight tube and the radiator is always full when it has cooled - had to add a little coolant the first 2 or 3 rides to get it working. I am thinking about trying a Brembo front brake reservoir...
Last Edit: March 11, 2009, 08:51:36 PM by Bill in OKC
DucHead
No garage queens
March 12, 2009, 03:37:37 AM »
Thanks Bill!
I wonder if the bottle would fit behind the CF radiator shroud on the right side of my bike? Could you give me the dimensions of your overflow bottle?
Quote from: Bill in OKC on March 11, 2009, 08:34:46 PM
... I am thinking about trying a Brembo front brake reservoir...
Holy crap! What's that hold...40 mL?
Last Edit: March 12, 2009, 03:47:09 AM by pompetta
"45"
phierce
March 12, 2009, 06:24:41 AM »
Quote from: pompetta on March 12, 2009, 03:37:37 AM
Thanks Bill!
What kind of rad shrouds you runnin'? DP
S4R
748
DucHead
No garage queens
March 12, 2009, 09:41:34 AM »
The overflow bottle from Advance Performance Accessories is about 4-1/2" x 2" according to an email from them.
It will fit directly behind the radiator on the right side if I either move the right fan, or remove it.
Does anyone think it would be harmful to run with a single fan? Mine only come on at 215° F, and the bike doesn't often get to that temperature.
Quote from: phierce on March 12, 2009, 06:24:41 AM
Yup. PM sent.
"45"
pigmy
March 12, 2009, 10:28:13 AM »
maybe a bottle like mine.i think it came from a 125 honda moto x.you could probably bolt it to the side of original airbox.
thats all i did here.
just go down to local wreckers and try to find something similar that might go between tank and airbox.
DucHead
No garage queens
March 12, 2009, 11:57:32 AM »
Quote from: pigmy on March 12, 2009, 10:28:13 AM
That's a great idea, but there is less than 1" between the inside of my tank and the airbox.
"45"
DucHead
No garage queens
March 21, 2009, 06:47:22 PM »
OK, I ordered and installed the overflow bottle from
here
. Thanks for the recommendation Bill!!
I cut this crude bracket which isn't visible with the cover in place (cover bolt holds the bracket in place):
Much better without the OEM overflow bottle:
"45"
Alexandre
Monstro
Reply #14 on:
March 21, 2009, 07:06:28 PM »
Quote from: pompetta on March 21, 2009, 06:47:22 PM
here
thats cool... [moto]
