January 08, 2025, 07:20:49 PM
the OFFICIAL Bikes of the DMF
147
148
149
150
172
Topic: the OFFICIAL Bikes of the DMF (Read 723730 times)
Curmudgeon
Re: the OFFICIAL Bikes of the DMF
Reply #2205 on:
January 17, 2012, 08:46:11 PM »
Quote from: Travman on January 17, 2012, 07:35:49 PM
I love Defenders especially in white. Why did they stop selling them here? You're a lucky man.
There is no way to fit SRS in a Defender due to the strength of that chassis. So after 1997, no more NAS Defenders unless the GVWR was greater than 8,500 lbs. which is, or was, the DOT cut-off. The Brand Manager who had done the Wagon with me was in Gaydon by then as liason to BMW. He did come up with a 110 HCPU crew cab which with a 130 axle could meet the spec, but with that springing the rear suspension was essentially rigid unless you carried 1,000+ lbs in the bed. We gave up. Cruel irony, the 110 crew cab with normal 110 springs became hugely successful in Europe. Still is with hunters/shooters with dogs.
More than you wanted to know? I could go on and on and on...
Mine was the first white wagon in the U.S. #021/500. J.P. Slavin also used to say, "Land Rovers are white". We have good taste...
Desert Dust
Ten Most Popular Uses for a
Reply #2206 on:
January 17, 2012, 08:48:24 PM »
Where are all of the "Bikes of the DMF?"
Grrrly
Industrial Grrrl
Reply #2207 on:
January 18, 2012, 04:00:11 AM »
yes, please less talk.. more photos of YOUR BIKES!!
The Evil Twins:
Urban Assault Vehicle:
2002 Duc M 6/900 Industrial Edition
Track Weapons:
2004 Suzuki SV650
2009 Kawi ZX-6R Monster Edition
The Bearded Duc
a.k.a. duc750
Reply #2208 on:
January 18, 2012, 11:48:23 AM »
Don't know if I've put one of these up yet...
There's still a bunch of things I want to do, hell even looking at the pic I'm saying "I wanna do this, this, this, and this..."
Good thing I started a "Ducati Fund"
2001 M750 - Sold
Desert Dust
Reply #2209 on:
January 18, 2012, 04:37:19 PM »
I like the exhaust. Is that your design?
gOoIe B
Reply #2210 on:
January 18, 2012, 04:47:19 PM »
Yeah, I'm intrigued by that muffler, I like it. Care to elaborate on that thing?
Nice dark
S2R 800 '07
Reply #2211 on:
January 19, 2012, 02:08:41 AM »
If I'm not mistaken, that's the 'stubby' or 'shorty' Termignoni without it's carbon sleeve.
Looks good
The Bearded Duc
a.k.a. duc750
Reply #2212 on:
January 19, 2012, 10:16:26 AM »
Quote from: Desert Dust on January 18, 2012, 04:37:19 PM
Quote from: gOoIe B on January 18, 2012, 04:47:19 PM
Nice dark
Quote from: stopintime on January 19, 2012, 02:08:41 AM
Looks good
Thanks guys
stopintime is correct, it's the stubby Termi with a Marving mid pipe. I just took the carbon sleeve off to see what it looked like at first and ended up liking it. It looks kinda Mad Max-ish!
It's still a little too dirty for me though, I wanna have someone break the welds and redo it a bit cleaner. Termi probably didn't care too much about aesthetics since it was supposed to be under a sleeve anyway. And I wanna have the tabs that hold the carbon sleeve removed, you can barely see them in the pic but they're on the top and bottom of the pipes right before the silencer.
2001 M750 - Sold
Nero-92
Reply #2213 on:
January 20, 2012, 04:47:45 PM »
Mainly because of safety the us motor vehicle people wanted land rover to fit air bags to the defender land rover said no it was an agricultural vehicle and at the time tractors didn't have air bags fitted so they were banned in the us your loss.
I am a bog snorkeler
Reply #2214 on:
January 20, 2012, 05:41:50 PM »
Quote from: duc750 on January 19, 2012, 10:16:26 AM
Have you thought about making, say, an aluminum sleeve for it?
The Bearded Duc
a.k.a. duc750
Reply #2215 on:
January 20, 2012, 09:23:30 PM »
Quote from: Buckethead on January 20, 2012, 05:41:50 PM
I haven't, but the carbon sleeve that it came with is essentially the same idea. The problem is, in order to get to the pressure clamps (to remove the silencer in order to remove the tire) the sleeve has to be able to come off which means it has to be left open on the mid pipe end and it just doesn't 'flow' well aesthetically to me. The mid pipe just ends up going right in to the open end of the carbon slip on.
The sleeve on the stubby Termi was basically made to contour the udder which I wanted as far away from my bike as possible!
I like the look of the silencer without the sleeve but the welds are horrible since they were meant to be covered.
2001 M750 - Sold
Reply #2216 on:
January 20, 2012, 09:42:14 PM »
I was actually thinking about an aluminum sleeve the exact same size as the can that's on there now, essentially making it look like a REALLY chopped-down stock-ish muffler. You'd keep access to the pressure clamps, and save the trouble of cutting and re-welding.
Quote from: duc750 on January 20, 2012, 09:23:30 PM
Can't fault you there.
The Bearded Duc
a.k.a. duc750
Reply #2217 on:
January 20, 2012, 09:51:13 PM »
Quote from: Buckethead on January 20, 2012, 09:42:14 PM
And you mean to end the sleeve right before the pressure clamps? If I'm picturing what you are then no, I haven't thought of that until now. I kinda like it, maybe I can extend the sleeve a little in the other direction as well so the exhaust exit part isn't so long either. There's a place around the corner from my house that does sheet metal work too!! Maybe I can get them to give me some scrap aluminum for little or no money!
Thanks Buckethead!!
2001 M750 - Sold
Reply #2218 on:
January 20, 2012, 10:07:00 PM »
Or you could end the sleeve at the end of the can - like the old aluminum sleeve on the DSS Monster stock exhausts - just to cover the crappy welds and make it look uniform.
Happy to help!
Enjoying the ride
Reply #2219 on:
January 21, 2012, 01:05:20 PM »
just a thought ... leave a gap between the can and the sleeve for cooling
as air goes thru when riding the outer sleeve wouldn't be so hot so that when you stop somewhere either you or someone gets a nasty burn due to the can being hot ... jsut sayin'
147
148
149
150
172
