Home made 696 tail chop
Started by DucatiSTi, March 14, 2009, 04:25:42 PM
DucatiSTi
Here is a mock up of my home made tail chop  :)
I have to TIG the indicators on, powdercoat and wire up all the lights
Thought I would give everyone a first hand look-wanted to see what everyone thinks
BucciMonster
IMG]http://i241.photobucket.com/albums/ff68/007wabbit/DSC01921.jpg[/IMG]
2009 696 Monster - Arrow Carbon slip-ons, Bitubo steering damper, DP oil cooler, DP Touring Seat, Rizoma tail chop, Rizoma Zero 11's, Stebel Nautilus horn, Ducati Euro shroud, Speedymoto sliders (axles and frame)
woppini
Looks good!!! if your going to spot tig while the plate is installed, dont forget to disconnect the battery.
 [thumbsup]
While you're welding - weld on a helmet lock? Wouldn't that be a handy place to have one?
OT_Ducati
looks good
just make sure the tire does't hit the plate
when suspension is fully compressed
99 M750, 94 900sscr, 75 xs650 street tracker
Quote from: OT_Ducati on March 14, 2009, 06:07:26 PM
looks good
full compression is something like 4.8 or 5.8 inches. go to ducati.com and check the specs.
needtorque
If you put another 30 degrees outward swing to that plate bracket not only will the plate have enough clearance and still be legible but it will also look a little better.  (aesthetics are important  ;D )
Who insures the FDIC?
DucatiSTi
Quote from: needtorque on March 14, 2009, 06:18:19 PM
Thanks for all the input
I think I will bend the plate outwards-the rear tire clearance is at about 3.5" (specs say 5.8")
Thanks for the welding tip-I will remove the whole assembly for welding
BucciMonster
Big Troubled Bear
Looks good, how about letting me have the templates so I can bend my own [thumbsup]
DucatiSTi
Quote from: Big Troubled Bear on March 16, 2009, 06:42:41 AM
I'll post pics and give dimensions after I'm done
BucciMonster
Big Troubled Bear
Quote from: BucciMonster on March 16, 2009, 05:55:06 PM
BucciMonster
Thanx a lot my friend [thumbsup]
DucatiSTi
Here are a couple of pics after welding and bending the plate up
Still have to powdercoat
BucciMonster
sfarchie
Nice job! Do you live in Canada (I think I saw a Canadian flag). Do you have reflector issues where you live? In CA, seems like a lot of riders are getting fix it tickets if they don't have reflectors around their plate.
Ray
SFaRChie
that looks great and the final angle of the plate looks very good for the bike.
DucatiSTi
Quote from: sfarchie on March 22, 2009, 10:19:11 AM
Yes, I'm in Toronto, Canada (we are just getting some warmer weather)
I haven't heard anything about reflector issues but I plan to install reflective rim tape in the very near future
BucciMonster
Holden
If reflectors turn out to be an issue, the vertical space above the license plate and between the turn signals looks like the perfect place to stick a long rectangular one.
