January 10, 2025, 06:50:34 PM *
Pages: 1 [2] 3   Go Down
Author Topic: "Scrambler" almost finished tease.  (Read 17559 times)
Pedro-bot
« Reply #15 on: March 25, 2009, 07:00:55 PM »
Can I ask what you used to make those tank badges stick? I have an identical set that I want to use on my project bike as well but I'm unsure of what to use to make them stick.
BTW, Very Nice Work!  waytogo
Big Troubled Bear
The wrong side of normal
98 m900 sold, Red 696
« Reply #16 on: March 26, 2009, 12:15:12 AM »
Awesome waytogo
dlearl476
« Reply #17 on: March 26, 2009, 08:39:46 PM »
It look's the "DOG'S", especially the spoke wheels  waytogo
Me likey!!  applause applause
 coffee
I thought they would be cool, but I had no idea of how much I'd love the look once they were on.
They were adhesive backed, and clear-coated over.  Anything you want to add, DP?  (I don't really know of anything special, but Ducpainter did the work.)
« Reply #18 on: March 27, 2009, 04:27:02 AM »
The badges you mention are actually decals. They come with the adhesive pre-applied. They are two layer vinyl and really pretty thick. Normally that is a bad thing. In this case they really stand up nicely on the reflective background.
If you have some of the aluminum badges that were reproduced for the original screw on application, I have some ideas.
Pedro-bot
« Reply #19 on: March 27, 2009, 08:16:26 AM »
I do have some of the aluminum badges. Yes, please share what ideas you have DP.  Grin
>>> OK, sorry, end thread jack. <<<
JEFF_H
« Reply #20 on: March 27, 2009, 10:23:29 AM »
the badges are flat and the tank is curved.
i started to bend mine and it looked liked they would crack so i stopped and used stickers instead.  Smiley
loves ze desmodromics.
« Reply #21 on: March 27, 2009, 10:25:25 AM »
Are they metal? Perhaps applying heat would help
JEFF_H
« Reply #22 on: March 27, 2009, 10:39:39 AM »
metal...but kind of potmetal lookin.
already moved on (i have a different tank now too)
thanks tho
kfmarshall
Properly cared for, it will always look like a
2007 Silver S2R1000
« Reply #23 on: March 27, 2009, 12:43:05 PM »
The problem is that with all the adpators in place, everything fits fine, but I can't get anywhere near the 70Nm of torque on the axle bolt without putting an unacceptable load on the bearing.  Apparently, it's due to the fact that the speedo drive for the 25mm axle is a few mm thinner than the same for the 20mm axle.  I also need to machine a speedo drive flange for the Alpina wheel.  I thought I could make an OEM one work, but I can't.
I don't understand one word you just said.
Pedro-bot
« Reply #24 on: March 27, 2009, 01:50:30 PM »
Werd.
Anyone got any experience with this scenario?
« Reply #25 on: March 28, 2009, 04:53:22 AM »
Werd.
I reformed a set for a customer.
No cracking.
Go for it.
dlearl476
« Reply #26 on: March 28, 2009, 07:59:37 PM »
Judging from my "success," neither do I.  Grin
No cracking.
Go for it.
Highly skilled tradesman make these out of flat sheets of aluminum.
The concept is similar, but a whole lot easier.  waytogo
« Reply #27 on: March 28, 2009, 08:39:44 PM »
But they have English wheels and shears and brakes and...
I used a wooden dowel, a hammer, and a sandbag. Grin
dlearl476
« Reply #28 on: March 28, 2009, 08:54:30 PM »
"A Poor Workman blames his Tools."   Grin
The point I was attempting to make was that it's a bit more complicated than "bending" it, but not much, as simply trying to bend it without resisitance WILL break it.  But little love taps against a sandbag will "reform" it just dandy.
btw, you're up late.  Waiting for F1 like me?  chug
« Reply #29 on: March 29, 2009, 04:39:45 AM »
I knew what your point was.
I was just joking around....although I am envious of the talents of people that do that kind of work.
Not an F1 fan...insomnia.
Pages: 1 [2] 3   Go Up
