January 10, 2025, 05:04:58 AM
ECU Price? Couple other questions
Topic: ECU Price? Couple other questions (Read 2978 times)
Clickjack
March 18, 2009, 08:23:33 AM »
Looks like I may be buying a very low miles full termi system off of a board member in the next week or two. I'm assuming it either doesn't have the ecu or can't be used on my bike as it has seen time on another bike, no matter how brief.
What is the price of the appropriate ecu for the termi kit on a 2007 S4R T.
Is there a reason I couldn't run the pipes with the stock ECU, until I could afford one?
A while back I was told 700.00. I can handle that. Though when I resently asked my dealer about the DP ECU he told me 1600.00. (more then I could do for quite a while).
Anyone ever compare full termi vs. Full arrow/power commander?
Thanks, and any other advice is welcome.
"They wanted Gold, we gave them lead" -John Wayne
JEFF_H
Re: ECU Price? Couple other questions
March 18, 2009, 09:02:44 AM »
Another option is to PM board member Monstermash for a stock ECU reflash
(I think motowheels sells a reflash kit too)
Clickjack
March 18, 2009, 09:07:03 AM »
How does it work?
What does it do compared to a new ecu or power commander?
Will it void the warranty?
hbliam
March 18, 2009, 09:44:10 AM »
I'm not sure when the "new" ECU deal started but I think you are part of the "old" ECU setup. Does your bike use the "red key"? If so that's the old setup. Those ECU's are non-interchangable after being mated to a bike. The new set up lets you move ECU's around and you can find the ECU's on ebay for a few hundred bucks. With what I suspect you have, the "old" setup, all you need to do is install a PC3 and have a custom map installed or built. The PC3 tricks your ECU into delivering more or less fuel, as appropriate. PC3 is about $300 with stock maps, a custom map runs about $250.
Clickjack
March 18, 2009, 10:09:24 AM »
My bike has the red key.
I can get a dynojet PCIII for right at 269.00. Would I still need another map? My dealer told me it couldn't be mapped or something like that, but that he thought the power comander was a good route, specially with the Arrows.
Can you guys explain open loop and closed?
Mr Earl
2003 M800 Dark
March 18, 2009, 10:14:45 AM »
If the Termi system you're buying comes with a DP ECU, and if that DP ECU model is for your model of bike, and if the owner never "mated" the DP ECU to his bike, then you can use it on yours. Lots of ifs, but worth asking about.
Leo Vince CF slip-ons, '01 SS900 fully adjustable Showa forks w/ST2 springs, rebuilt S4 shock w/Ohlins spring, 748 dog bone, Swatt clip-ons above the triple, Sargent seat, Duplicolor-Dark seat cowl, Rizoma grips, Techlusion TFI, SBK front fender, Evoluzione slave, BMC sport air filter, 14-tooth sprocket, Desmotimes caseguard, S2R side panels, Pantah belt covers, fake CRG LS mirrors, extra black zip-ties, right grip control imprint on tank, de-cannistered, Ducati Meccanica Bologna key ring
TAftonomos
is without a monster :(
March 18, 2009, 10:16:31 AM »
It doesn't, the termi ecu is gone/being used. I PM'd him about it earlier, it's a 10 mile old used system sans ecu for $1200.
That termi exhaust btw has no provisions for an O2 sensor, so you'll need to do something about that.
Nemisis or flash, or DP ecu.
Guy I use for flashing made me an ECU that was originally from a S2R1000...works great on my 07. Since I can run the bike without the factory gauges now, IF you wanted a DP ecu I could sell mine to you....but it isn't going to be cheap either. Would be the gauges, lockset and ecu "combo"
Last Edit: March 18, 2009, 10:18:20 AM by TAftonomos
MyDucParts.com
corey
'06 Tang/Black S2R800
March 18, 2009, 10:52:47 AM »
Quote from: Clickjack on March 18, 2009, 10:09:24 AM
$269 + a custom dyno tune.
call it $500.
TAftonomos
March 18, 2009, 10:55:14 AM »
don't forget getting rid of the O2 sensor somehow
MyDucParts.com
hbliam
March 18, 2009, 11:09:07 AM »
We need Speeddog or someone else to jump in here.
My understanding is the o2 sensor thing is part of the "new" style ECU and that the old "red key" ecu's don't have the o2 sensor to deal with. Is that right or wrong? Or is there some overlap in the last year or so? My hyper is no red key, with o2, and needs the new ecu, remap, or nemisis to work correctly with a full exhaust. I can also use the fatduc o2 tool to trick the sensor which i am told only affects the first 20% of throttle opening anyway.
hbliam
March 18, 2009, 11:14:33 AM »
Relevent threads:
http://ducatimonsterforum.org/index.php?topic=655.0
http://www.ducati.ms/forums/showthread.php?t=59856&highlight=open+loop&page=2
moto
March 19, 2009, 10:58:18 PM »
Quote from: JEFF_H on March 18, 2009, 09:02:44 AM
ProTune ECU Remap Kit
can re-flash your OEM ECU with a "DP Map" for less than half the cost of a DP ECU.
-M
www.motowheels.com
96 M944
98 900SS FE
01 996R
02 MV Agusta F4 750
05 999R
06 SC1000
07 1098
08 M696
