February 08, 2025, 01:17:29 PM
OZ monsters
hedders for my 620 ?
Topic: hedders for my 620 ? (Read 1511 times)
feral
March 19, 2009, 01:24:52 AM »
I have a 2005 620 arrows on it but they dont make headers for them does anyone know of someone in Sydney that could or has made a set? 2 into 2
feral
loony888
"I WAS GOING HOW FAST, OFFICER?"
Re: hedders for my 620 ?
March 19, 2009, 02:44:29 AM »
i can't point you in the direction of anyone unfortunately, but the standard exhaust headers would probably be best anyway. it's only a little engine and although V twins are renowned for being torquey the 620 isn't a powerhouse, if you went for a larger diameter you would lose drive low down and unless you wanted to rev the tits off it everywhere you wouldn't find it again. i'm pretty sure they're stainless steel as standard so if you just want to tidy it up they will polish up nicely.
paul.
HERE AND NOW 12 DIAVEL AMG
93 888 RS
09 1098R BAYLISS
07 Husqvarna TE 450
GONE BUT NOT FORGOTTEN 03 S4R 95 900SL
01 S4 93 900M
96 748SP
Betty
March 19, 2009, 03:09:18 PM »
+1 on what Loony said. But why are you wanting to change the headers?
When Jukie had her pipes put on we had the standard headers polished - they are stainless but apparently have some type of coating on them from the factory which doesn't respond well to heat (so they get black and ugly pretty quickly). Once polished up though the look alright, if you are into that kind of thing
and will 'bronze-up' with a bit of use ... after a while they will probably return to ugly black ... then you can polish them again.
My bike is obviously a different setup, but the exhaust doctor kept the standard headers as they were a slightly smaller diameter to what he otherwise would have used. Apparently it is better to gradually increase he pipe diameter so the standard stubby headers were retained (but polished
feral
March 19, 2009, 06:24:15 PM »
Thanks guys for the info i know its a little engine for reasons i have to keep her for 3 years before i can upgrade . Im going to run the NCR bore kit will put it to a 750cc and im going to black heat wrap it anyway i might email NCR and ask them what they thing once i have the bore kit done . Please anyone else have any thoughts.
bsbd feral
loony888
March 20, 2009, 01:57:21 AM »
I'll bet the NCR big bore kit will cost a fortune!!!
you could try
www.ferracci.com
or better still,
www.cacycleworks.com
i'm reasonably sure both do a big bore kit, the ferracci one will have fbf branded pistons but they're made by wiseco and chris at cycleworks may be able to help with a mahle kit. it's just a suggestion though.
Oh, if you're upping the capacity to 750cc shop around for a 2nd hand set of 750 monster headers, get em polished and fit them, they should do the trick.
paul.
93 888 RS
09 1098R BAYLISS
07 Husqvarna TE 450
01 S4 93 900M
96 748SP
brad black
March 20, 2009, 03:07:03 AM »
all the 2v monsters - 600 to 1000, run 40mm headers.
Brad The Bike Boy
http://www.bikeboy.org
loony888
March 20, 2009, 03:25:10 PM »
Quote from: brad black on March 20, 2009, 03:07:03 AM
well there you go! no need to change em, just give them a polish when it's apart for the big bore kit.
93 888 RS
09 1098R BAYLISS
07 Husqvarna TE 450
01 S4 93 900M
96 748SP
The Don
March 20, 2009, 06:27:04 PM »
How about Vee two in WA.
http://www.veetwo.net/index.asp
I don't know if they make a big bore kit but worth a call, you wont have the convertion of the Australian Peso to worry about either.
Don
Wise men talk because they have something to say; fools talk because they have to say something. - Plato
brad black
March 20, 2009, 07:09:42 PM »
get your cylinders bored by electrosil in melbourne or anyone else close to you and get the ferracci 620 big bore pistons or some sort of 750 piston - std for low comp or whatever other. it just becomes a 750.
Brad The Bike Boy
loony888
March 20, 2009, 08:01:01 PM »
electrosil quoted me something stupid to replate mine, IIRC it was around $550 each?
so the stroke is the same between 620 and 750 then?
93 888 RS
09 1098R BAYLISS
07 Husqvarna TE 450
01 S4 93 900M
96 748SP
Two dogs
March 21, 2009, 05:45:54 PM »
Quote from: Betty on March 19, 2009, 03:09:18 PM
Hi Betty Jukie's pipes look nice and shiny are they stock ? if so can you tell me what process and materials you/she used on them to get them that way
Mine are ugly looking tried wrapping them in graphite tape but keep scraping them so that looks shit as now they are all frayed .
thanks
dez
Betty
March 22, 2009, 01:25:28 AM »
Dez,
Yes they are stock headers with custom slip-ons all stainless. As for the process I don't really know to be honest, we had it done when the slip-ons were made ... I am mechanically inept (just ask anybody who attended the last maintenance day). But apparently getting that initial factory coating off is the hard bit.
If I remember correctly Egas has done the polish thing and had a bit of a write-up (probably on the other board) ... Egas, is that right?
loony888
March 23, 2009, 01:48:47 AM »
apparently muriatic acid cleans the headers up almost instantly, from there it's polish, polish, polish.
paul.
93 888 RS
09 1098R BAYLISS
07 Husqvarna TE 450
01 S4 93 900M
96 748SP
heatherp
March 23, 2009, 02:58:12 AM »
Quote from: loony888 on March 23, 2009, 01:48:47 AM
paul.
Do people still call it muriatic acid? Not heard it called that before (had to google it
) - way before my time. And where would you be getting it from - is it full strength? ie 32-33%
Betty
Reply #14 on:
March 23, 2009, 03:11:56 AM »
... and Loony, is it necessary to use the acid (take that whichever way you want) before the blackness is baked on over several thousand k's?
