February 07, 2025, 03:32:11 PM *
Author Topic: Anyone have these caliper bolts?  (Read 1937 times)
b.
« on: March 20, 2009, 05:59:21 PM »
Looking for the two lower bolts that hold the two halves of the caliper together...
2005 M620 | so*cal | terapia.
« Reply #1 on: March 20, 2009, 06:01:47 PM »
8mm, i believe.. 15mm length.  not hard to find (double check the length).
IIRC they are 8.8.  I've had no problem using A2 stainless for this location as they are just olding the two halves together, not under much torque.
b.
« Reply #2 on: March 20, 2009, 06:07:57 PM »
The bolt head says M 10.9 and it's about 45mm in length.  I'm worried about getting just any old bolt because of the heat it's subjected to...
« Reply #3 on: March 20, 2009, 06:18:03 PM »
i am surprised they are using 10.9 there, but that's fine.  that's longer than i thought though.
A4 stainless is mostly equivalent to 10.9 (A4 not A2) but you can find 10.9 or even 12.x series bolts around.
If you really want to be anal, buy some 12.8 bolts with the Dacromet coating.  heat, chemical, friction, radiation, and Beezlebub resistant.  might be harder to find.
Maryland Metrics has plenty of bolts of all sizes.
DanTheMan
« Reply #4 on: March 20, 2009, 09:43:36 PM »
If you know what you need, call Mr Metric in Sj, he'll have them. Have to call them ahead of time, they do will call only.
2008 KTM 690 SMC
2006 749 Dark- Sold
2003 M630ie Dark - Sold
2003 CRF175F
1996 Honda CR125R - Sold
b.
« Reply #5 on: March 21, 2009, 11:46:51 PM »
Thanks for the tips everyone...I got lucky at Munroe's as they had just taken apart a caliper for parts and I got to take the bolts I needed.
