February 08, 2025, 12:52:58 PM *
Author Topic: Fuel Tank Clip  (Read 1235 times)
dragonworld.
I can make like a tripod with my.....
« on: March 23, 2009, 06:01:35 PM »
Bugger !!  Roll Eyes
Murphy has struck again, while checking out a sticking choke cable (750) I went to raise the fuel tank and the catch/lever assembly came off in my hand!!  Shocked
It looks like the later ones might fit the same also, (DS)?? Huh?
Has anyone seen or heard of one of these kicking about??
Thank yuzz all.  Sad
Jukie
I need a
Paradise
« Reply #1 on: March 23, 2009, 07:36:53 PM »
Hey Dragon, my catch lever is as loose as my chain is or was. i haven't worried about it but it does unlatch easy, like its owner  Cheesy
Before Honda CB125N
          Suzuki GS125
Now.   Ducati 620ie
          Lambretta Li150
          Ducati S4RT
dragonworld.
« Reply #2 on: March 23, 2009, 09:55:13 PM »
You izz a RUDIE !!  Evil Grin  Wink
Jukie
I need a
Paradise
« Reply #3 on: March 23, 2009, 10:01:16 PM »
hhmmm i will have to say yes to that Evil applause
Before Honda CB125N
          Suzuki GS125
Now.   Ducati 620ie
          Lambretta Li150
          Ducati S4RT
dragonworld.
« Reply #4 on: March 23, 2009, 10:08:09 PM »
and a NUDIE !!
Jukie
I need a
Paradise
« Reply #5 on: March 23, 2009, 10:11:22 PM »
and a JUKIE
Before Honda CB125N
          Suzuki GS125
Now.   Ducati 620ie
          Lambretta Li150
          Ducati S4RT
dragonworld.
« Reply #6 on: March 23, 2009, 10:24:24 PM »
Da wun an' only !!  waytogo  bow down
loony888
"I WAS GOING HOW FAST, OFFICER?"
« Reply #7 on: March 23, 2009, 10:34:49 PM »
bloody hell you two!!!!
jukie, you can adjust the clip, it winds in and out on a thread, and dragonworld, they all fit the same, my 888 has a black plastic one and my S4R has a metal one and they're interchangeable. the black plastic one hasn't been available for a while though apparently.
paul.
                                              93 888 RS
                                              09 1098R BAYLISS
                                              07 Husqvarna TE 450
                                              01 S4         93 900M
                                              96 748SP
dragonworld.
« Reply #8 on: March 23, 2009, 10:46:38 PM »
Yep, had a look at the one on my DS, and it fits the same so I found one on fleabay US for under $50 delivered!!  Grin  waytogo.
Thats what busted! Roll Eyes
The plastic.  Sad
nuggethead
« Reply #9 on: March 24, 2009, 09:28:01 PM »
Mine was loose for some time - adjusted it to its full adjustment - still loose.
Turned out the fuel tank clip bracket seated under the ignition housing was bent. I went to it with a hammer (preferably a large one with flat smooth surface) on a firm surface to flatten it out.
Check it - it may be the problem.
The nugget factor!
« Reply #10 on: March 25, 2009, 01:49:52 AM »
You do want to make sure the clip does up tight enough to stop the tank wriggling - you don't want the hinge to be taking all the twisting forces - the clip is there to hold the tank down on those rubber blocks on the frame - if you leave it loose you risk cracking the hinge welds and having the tank start leaking...
big
monstermick58
« Reply #11 on: April 05, 2009, 10:53:35 PM »
My plastic one broke some time back, bought the metal one but I had to use the old metal bit that hooks over the frame bit as it was slightly different.
                                                        Mmick
Dockstrada
« Reply #12 on: April 06, 2009, 01:28:56 AM »
The plastic.  Sad
Hey dragon I have one  waytogo
If I wasn't who i was, I wouldn't be who I am !
dragonworld.
« Reply #13 on: April 06, 2009, 02:54:32 PM »
                                                        Mmick
Yep to that, and because the 750 has the locating lip the other way round, I found it was easier to mount the metal clip the other way round from standard so it located better. Other than that it fits a treat, and metal is a fair bit stronger than plastic. waytogo
Having said that, it DID last 11 years.  Grin
