January 10, 2025, 05:37:23 AM *
Author Topic: Mess o' wires  (Read 2231 times)
kfmarshall
Properly cared for, it will always look like a
2007 Silver S2R1000
« on: March 23, 2009, 06:54:39 PM »
Okay - so I got rid of my big ol' pumpkin dome turn signals, and replaced them with Rizoma Track 77's.  So, all's well, I didn't even short anything out this time.  However, I've now got two massive black boxes, two feet of wiring, and two more little french fry shaped resistors stuffed in there behind the headlight.
The question in this is: how are people managing all the junk behind the headlight?  Electrician tape?  Custom fabrication?  The shrink-wrap stuff?
I know there are some good idea out there... hit me up.
Thanks,
Kevin
« Reply #1 on: March 23, 2009, 06:56:57 PM »
Heat shrink with a little silicone in the ends is a good idea, just from a reliability standpoint.
Otherwise, your ability to hide it is limited by the size/height of your gauges and the volume of your headlight.
DucHead
No garage queens
« Reply #2 on: March 23, 2009, 06:59:23 PM »
Thanks,
Kevin
I just re-wired everything under my seat for the brake light and turn signals, as well as front turn signals.  For me, the two resistors for the rear turn signals obviated using resistors up front where there's less space.
I just shortened all the wires and bought new connectors, check out this thread: http://ducatimonsterforum.org/index.php?topic=20916.0
kfmarshall
2007 Silver S2R1000
« Reply #3 on: March 24, 2009, 05:30:37 PM »
Thanks man - I'll give it a shot.
Kevin
corey
'06 Tang/Black S2R800
« Reply #4 on: March 25, 2009, 07:16:31 AM »
I was able to wrap the excess wire for each front turnsignal into a small budle with a bit of electrical tape. Keep in mind i was VERY neat about everything. Then i used a bit more tape to secure that small bundle to the resistors (the NARROW black box). I then took the black LOAD boxes (the fatties) and stuffed them into a nice spot above the bottom triple, BEHIND (tank side) of the headlight U-Bracket. I think took the budled resistors and wire, held them against the back side of the load boxes, and zip-tied everything together against the U-Bracket. One bundle on each side, worked perfect, plenty of room. Nice and neat as well.
To prevent the electrical tape from coming undone, which is has a tendency to do, I made sure my zipties were very secure, and were directly on top of the seam of the electrical tape.
I have considered fabricated small plates to cover the spaces between the signal/headlight brackets, and the headlight/gauges.
I'll let you know if i ever get around to it
As far as rears, i rerouted everything and cleaned it up. It's easier back there.
kfmarshall
2007 Silver S2R1000
« Reply #5 on: March 25, 2009, 11:33:53 AM »
Sweet - that sounds like a good option... I'm gonna give that a shot.  If you do fab something, send some pics... I'm interested in doing that myself, although I have no idea how to.
Thanks,
Kevin
Cider
« Reply #6 on: March 25, 2009, 02:33:28 PM »
I'm thinking about trying some of this stuff for a wiring project on another bike: http://www.cabletiesandmore.com/BraidedSleeving.php?gclid=CITFpLj2zpECFQKzPAodhHFNBw
DucHead
No garage queens
« Reply #7 on: March 25, 2009, 03:51:03 PM »
I ordered some of this stuff from usplastics.com
kfmarshall
2007 Silver S2R1000
« Reply #8 on: March 27, 2009, 04:48:32 AM »
Thanks Cider - I think this might be the answer.  I'm going to see what my local electrical supplier has in stock.
'ppreciate it.
kevin
Cider
« Reply #9 on: March 29, 2009, 09:37:28 AM »
BTW, I ended up ordering from this place instead, because they had smaller minimum quantities: http://cableorganizer.com/wire-management/
Also, check out their 2:1, 3:1, 4:1, and 6:1 (!!!) heat shrink tubing.  I got some 3:1 stuff to secure the sleeving and clean up some other areas.
