My new Ducati powered Cagiva Sportbike...
Started by BellissiMoto, March 24, 2009, 06:15:58 AM
BellissiMoto
A 1985 Cagiva Alazzurra in excellent condition powered by a Ducati 650 Pantah motor.
I picked it up yesterday, and I gotta say this bike is fun!
It definitely takes off, handles, and stops pretty well for a 23 year old motorcycle.
BellissiMoto
#1
Check out the Alazzurra group on yahoo groups.
http://autos.groups.yahoo.com/group/Alazzurra/
Same bike under a diff name
Cagiva bought Ducati and redesigned the Pantah 600TL's fairings and updated the electrics and used the engine from the 650SL.  Otherwise, identical bike.  The engines, frames and everything were assembled and shipped to Varese for final assembly, so the VIN says Varese, but they were built in Bologna.
Your bike says "Cagiva" but it's a Ducati, heart and soul.
If you have the dry clutch version, it says HC on it but if you look at it upside down, it is strangely familiar.
Here is the 650 TL.. Look at the exhaust hangers / rear peg mounts.  Identical to the Ally's.  This style is unique to the 600TL among Pantahs.  The first Ally's also had chrome engines, Cagiva decided to do them in black after 84.  The frame for the 600TL and the Ally are identical and in Cagiva's marketing literature, the USA version of the Ally 650 with a half fairing was called a TL (NOT THE 650SS version -- full fairing)
Statler
Sounds like a cool bike.  Can't see the pics.
and you know within 5 posts someone is bound to ask the question.    ;D ;D ;D (all in good fun)
Quote from: Statler on March 24, 2009, 07:04:34 AM
yup..... is it registered?
Statler
BellissiMoto
Pictures fixed.
Also, bike is registered and insured.
That is a wet clutch version, GT(TL) model.  Cagiva alternately called it a 650 GT or 650 TL in the USA.
it has the same wet clutch as the early M600 and M750, so plates are interchangeable as is the piston (and it's a VERY good idea to open that sucker up and replace the piston seal with a modern EPDM material type, the originals are natural rubber)
front brakes are the small F05 type, which is the same as the back on that model.  pads are easy to find, and TONS of bikes have that model caliper.  Just search "Brembo F05".  Also, the rotors are the same on the front and back (260mm).
Forks are 35mm Marzocchi and occasionally Paioli.  Rear shocks are the Marzocchi E82 Stradas and are soso, there are aftermarket shocks available.  I like the Progressive Suspension 14 series, which are cheapish and very good for the price.  You can get the Ikons which are Koni copies but thye are pricey.
Plenty of tire options available, I like the Bridgestone BT45s or the Dunlop K591..
Statler
cool scoot.
and lots of good info from 'tizzz.
yamifixer
I HAD ONE JUST LIKE THAT. great ride. turns great and the brakes are scary good until they get hot.
get a clutch rebuild kit on order, your going to need it and A BATTERY TENDER, plug it in every time you get home that little tiny clock in the dash will kill the battery in about 45 hours.
congrats great, seldom seen bike.
Valve Springs are EVIL
Quote from: yamifixer on March 24, 2009, 09:17:58 AM
yeah, that clock is a POS..  they work, but they do drain the battery
i swapped mine with a combo volt/amp meter.  Much more useful
BellissiMoto
Quote from: ducatizzzz on March 24, 2009, 09:20:55 AM
Thanks for all the information and the messages Ducatizzzz,
I'll definitely be replacing that clock, you wouldn't happen to have any recommendations as to which one to use/where to get it would you?
Quote from: BellissiMoto on March 24, 2009, 06:26:32 PM
The one I got is a dual volt/ammeter and comes from a cockpit (airplane) supplier.  I got it free from my uncle who is a pilot, and they are not cheap, i.e. >150-200.  You can get almost any 2" series voltmeter or ammeter from Autozone or Advance Auto for around $20 or cheaper if you look online.
if you REALLY want a dual read setup, skulk around ebay for a "2 in 1" volt/amp meter.  they come up frequently, but you'll have to do some home-engineering to install it, they are usually used.
You can put any 2" series cockpit gauge in that spot.  Once you open the panel, you'll see it is easy.
I've found the ammeter to be less than useful overall, the voltmeter tells me when the battery is weak, but the ammeter can tell me that the alternator's health or how the battery is charging, which is great, but useless 99% of the time, and once it goes, it really goes quick.
If I hadn't gotten that gauge free I might have put an oil temp gauge instead, they are easy and you can plug the sensor into a bunch of different places:
http://www.sasab.com/Gauge-oil-temp-d960.aspx
You can also get oil pressure gauges, but the senders are usually kind of large.
Basically, you can put ANY 2-2.25" gauge in that spot and it will be better than the clock for your riding.
