New Headlight and Clip-ons Test Fit - NOW WITH PICS
Started by desmotwin999, March 24, 2009, 09:12:47 PM
desmotwin999
hey all, i just finished the first test fit of the new speigler headlight and lsl clip-ons. i will not be reusing the stock headlight bracket. I now have 2 metal inserts sticking out the bottom of the top triple where the gauges install. does anyone know if these can be removed?
El Matador
Dremel  [thumbsup]
btw, awesome headlight, looks very nice
Ranger06
I'm thinking about going with that headlight too, any pictures?  Did it mount up pretty easy?
2008 695 Dark
herm
#3
those posts are pressure fit and can be removed with a pair of vice grips. in fact, when i removed my stock headlight setup (specifically the U-bracket) they came out with it.
just wiggle them around, maybe use a little lube... [thumbsup]
edit: just looked again and realized your bike is an s4r........but should be the same as my s2r
desmotwin999
Quote from: Ranger06 on March 25, 2009, 01:25:12 AM
So far install has been pretty simple. Everything just basically plugs in. The most difficult part will be trying to figure out how to secure the wires without the headlight U bracket. I was hoping to drop the gauges down but unfortunately, there is not enough space...the headlight in its lowest position is about a half inch below the gauges.
Quote from: herm on March 25, 2009, 02:02:35 AM
That's good advice for countless occasions!  ;D [laugh]
TAftonomos
it's a roll pin.  Grab with a pair of vicegrips, twist and pull.
Nice,  I'm surprised I haven't seen this light on a Monster before.  I think I've seen it on a custom Multistrada though.  Please post up more pictures once you have the gauges back on.
DarkStaR
Just screw in the appropriate sized screw into the triple to push the rolled pin out.  Works like a charm.  [thumbsup]
DucHead
What are the other set of brackets above the top headlight bracket?
herm
Quote from: pompetta on March 25, 2009, 04:14:06 PM
clip on brackets [thumbsup]
DucHead
herm
desmotwin999
Quote from: herm on March 25, 2009, 09:22:32 PM
or bull horn mounts?
they could be!!
;D
LOL - now why didn't I think of that!
ok, so here is another photo with clip-ons installed. The wiring coming off the controls is a bit of a birds nest...is there any way to clean that up or is that the way it supposed to look?
