January 10, 2025, 05:31:06 AM *
Author Topic: Need help: CW tail chop on '99 M900  (Read 1285 times)
mojo
'99 M900S
« on: March 25, 2009, 06:44:20 PM »
Just got a tail chop kit that is supposed to work on all monsters from '99-'07, but the brackets for the signals won't work because the seat latch is in the way.  From the pics I've seen, it looks like the frame and seat latch is different than my bike. bang head  The only way I can get the signals mounted is if I mount the brackets UNDER the frame, but then the signals are a lot lower than I would like.  I wanted the signals to tuck up under the seat cowl like all the other tail chops I've seen.
If anyone has any pics/tips on how to make this work, I'll buy you a beer. drink
« Last Edit: March 26, 2009, 03:49:47 AM by mojo » Logged
Some people are like slinky's.  They serve absolutely no purpose, but they always bring a smile to your face when you push them down the stairs.
corey
'06 Tang/Black S2R800
« Reply #1 on: March 26, 2009, 07:00:27 AM »
pictures of the problem would be helpful in coming up with suggestions Smiley
snap some shots and i'll see if can't figure anything out...
Stangman
« Reply #2 on: March 26, 2009, 07:29:26 AM »
Did you relocated your latch cable?  You usually have to do that when you chop the tail.  I have signals integrated into my tail light so I didnt have to worry about side signals.
As mentioned, take a pic or two and we can try to help.
mojo
'99 M900S
« Reply #3 on: March 26, 2009, 03:02:12 PM »
Here are a few pics of the latch, cable and signal bracket.  The biggest problem I have is how to reattach the cable with the signal bracket tight against the latch.
Stangman
« Reply #4 on: March 26, 2009, 05:03:24 PM »
Are you sure it goes upward like that?
I would think it would angle down so the signals are lower...
Is there any info that came with the part?
mojo
'99 M900S
« Reply #5 on: March 26, 2009, 05:28:52 PM »
that's how they are shown in the instructions so the signals are level with the tail lamp, but the pics that came with the instructions show a newer bike with the other latch.
drew.bradshaw
m750
« Reply #6 on: March 26, 2009, 06:21:48 PM »
drill new holes that are higher up maybe?  i'll take pics of what i did and post em tomorrow.. i think i spent 8 dollars and a six pack.  your latch is completely different then mine (2000 750).  maybe a new old latch will fix your clearance issue.
mojo
'99 M900S
« Reply #7 on: March 26, 2009, 06:27:29 PM »
If I change the latch, then I'd probably have to get a matching seat too.  That would probably be the most expensive Monster tail chop ever.  I might just end up making some new brackets to get the signals to fit.
drew.bradshaw
m750
« Reply #8 on: March 27, 2009, 06:42:01 AM »
touche  Tongue
