January 30, 2025, 07:21:46 PM *
News: Please Help
Author Topic: 1000DS, Belt offset from roller, question.  (Read 1187 times)
colin748916
« on: March 27, 2009, 01:25:37 AM »
I have just changed the toothed belts on my 2006 S2R1000 and when rotating the belts keep wandering outwards and finally line up with their outer edges 1-2mm off the edges of the cam rollers. This can't be ok, can it? The drive rollers are correctly mounted but not yet fully torqued, what can be wrong?
« Reply #1 on: March 27, 2009, 08:37:46 AM »
Try torquing the pulley nuts down all the way, see if that does it.
J.P.
« Reply #2 on: March 27, 2009, 11:36:02 AM »
+1
And- how did you set tension?
'06 S2R1k- Have a nice day! Smiley
colin748916
« Reply #3 on: March 27, 2009, 01:16:19 PM »
Both belts are still a bit slack as I copied the tension of the old belts by meassure. One was very tight, the other fit the 5mm Allen. I plan to trailer the short way to my dealer and have them set the correct tension. But first I would like to see the belts track correctly, I will set the tension to the specified 140Hz and see if that helps.
2003 M1000s
« Reply #4 on: March 27, 2009, 01:29:10 PM »
That spec might be high.  There are un-official opinions that belts that tight also cause pulley bearing failures.  Check with your dealer and see what they use.
