chain maintenance question
Started by fastwin, March 29, 2009, 05:51:07 PM
fastwin
OK, we all know how old school I am... it's a given. I have been oiling chains the same way since the mid 60s... Taco and Rupp mini bikes, Bridgestone 175s. Enough with memory lane. Dealing with all the excess sling off has been part of my riding for 45 years as much as bug guts on face shields and trying not to crash. I thought cleaning chain oil sling off was a prerequisite and a mandatory act to justify you riding your bike. It was just part of it all like adding gas and checking tire pressures and balance.
Anyway, I take the Monster into High Five Cycle recently to get a fresh inspection sticker. The chain was bone dry so I juiced it up with Maxima Chain Guard lube before I went. I've used a million others but have stuck with this for several years. Of course by the time I get to the shop excess s#@t has been slung all over the rear wheel, swingarm and assorted rear bodywork. The usual mess.
The inspector at the shop prepares to take her for the post look over inspection ride and I warn him to be careful of all the chain lube sling off. After the ride, while he's slapping on the new sticker, he asks "why don't you use chain wax instead, no mess". We talk about it for a while, of course I have heard of it but have never used it. He and another mechanic swear by it and say they enjoy the no fuss/no mess benefit over spray on chain lube.
My question is how many folks use old school spray on chain lube like me and how many use the spray on chain wax. I know Maxima makes a spray on chain wax in the same line up as the spray lube I use. Feedback people!! How's the wax over the standard chain lube? Opinions are welcome. [thumbsup] Just curious. I'd like to try the wax, sounds like sloppy clean up could be a thing of the past. That sure would be nice. [clap]
caffeinejunkee
I use maxima wax on both bikes. I get some fling but it's minimal and mainly on the inside chain guard.
Samsonite
I use the maxima chain wax lube and seems to be just fine.  I usually just spray it on wipe with a rag.  I like to run spin the wheel and grip the chain slightly with a rag as it works around the sprocket.  About every other lube I do the same thing with wd40 to clean all excess gunk off before applying wax.
Suzuki DS 80   Suzuki SP 125   Suzuki GSXR 1000   Ducati M600   Ducati SC 1000   Ducati S4R 1000   Ducati PS1000LE   Ducati 1098S   Yamaha YZFR 1000   Yamaha YZFR 600   Ducati Sport 900   Yamaha YSR 50   Triumph Daytona 600   2006 Suzuki GSX-R 600
caffeinejunkee
The last time I started using Kerosene instead of WD before the Maxima.  [thumbsup]
Duc L'Smart
well, according to Randy- oh, nevermind...
'07 1098s, '06 Paul Smart LE, '99 BMW K1200RS, '73 BMW R75/5, '67 Ducati Monza 250 Bevel Drive, '63 Vespa GS 160
Cher
I used WD40 on my 620 to clean and lube the chain.  Of course I found out later this was WRONG  :o  Ended up getting about 12,000 miles on the original chain doing it that way before it got rusty and had a kink or two.  Go figure  [cheeky]
Replaced that chain and have since used only Maxima chain wax.  I don't like it as much as WD40 because it doesn't clean the links very well... but there is no mess (wasn't much of a mess with WD40 either  :-X  ).
On a related tack; how often are y'all replacing chains?  My '04 999 is still on its original chain at 19,000 miles.  Sad, I know...  [laugh]
At the risk of bucking the trend:
Du Pont Teflon Multi-Use Dry, Wax Lubricant.
$5/can from Lowe's or Home Depot.
O-ring safe.
Dries clear with almost no fling.
Smells like pina coladas. No, seriously.
Also, umm, I'm sure you know this already, but if you wax/lube your chain after you ride, it flings less. Just sayin'.
fastwin
#7
Quote from: Tommy on March 29, 2009, 05:59:08 PM
I do the same thing but with the Maxima chain lube. And yes, I do lube the chain after rides when it's hot. Not on the Monster as described in this instance but 99% of the time I do it after rides. May try the wax just for a change. I googled it and found several motorcycle sites that loved it. A negative comment here or there but a big majority approved. Even found a mountain bike site that liked it but said it was probably better for motorcycles. Sounds like a winner. Couldn't hurt.
maxima wax for both cleaning and lube.  it costs more.  sometimes i use the wd40 when i feel ghetto, but then dry it all off and soak it down with maxima wax after it sits overnite and drips.
Samsonite
she does look like a horse.....
ghetto-T
RED
Ronr
Maxima Chain Wax here too, for a long time.  Every 500 miles, after a ride when it's warm, clean up afterwards with WD-40 on a rag.  I have very little problem with goo-fling.  So I got that going for me, which is nice.
Samsonite
Quote from: Ronr on March 29, 2009, 07:46:58 PM
[popcorn]
muskrat
"there's something about Mary" in that one  ;D
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
RED
Quote from: muskrat on March 29, 2009, 08:44:11 PM
You are one sick puppy.  [evil]
