Spark Plugs,etc.
Started by calscrazy, April 01, 2009, 05:37:15 AM
calscrazy
i have a question for some other D.I.Y. which plugs do you use and is the dealer the only place to get the belts for my 695? i know for a fact i don't have to spend $20 a plug when my company has accounts with every automotive parts dealer in the area. all help is appreciated.
home will always be between the red and rio!!!
2007 m695 errr recently passed away
$20 :o
Get the NGK DCPR8E, part #4339, should be around $4-5 a plug.  Part # is important so you get the right size hex and the removable terminal.
Porsche Monkey
I've found the correct NGK spark plugs in stock at Cycle Gear for 2 bucks each.
needtorque
chris at ca-cycleworks is a sponsor here and he has belts for much better prices than the dealer.
Who insures the FDIC?
♣ McKraut ♣
Quote from: needtorque on April 01, 2009, 10:34:24 AM
and he has the correct NGK spark plugs
-  Dallas, TX
needtorque
teddy037.2
+1 on NGK.
your manual will have the part # in case you forget...  [drink]
calscrazy
ty folks for the help. duc omaha gave me a factory champion number and since i have no real performance upgrades i will use them for now. next i will need to ca-cycleworks. thanks again for the help
