Need Help mounting a Power Commander on 2004 M800
Started by Spyvito, April 03, 2009, 01:16:16 PM
Spyvito
Hope you guys can give me a hand.  I can't figure out where to place the Power Commander I just got on the 2004 M800.  Top of the battery won't work because the tank won't close.  Sides of the battery have fuses and relays.
I'm guessing somebody else has run into this so please suggest.  A picture would be dandy.
Thanks
I think the recommendation from DynoJet is to mount it under the seat. Not sure if the wires will reash, but it should fit. Have you tried removing the insulation from under the tank? You don't really need it...
ghostface
On my old '03 M800 I mounted mine (velcro attached) to the rear of the battery. I'll try and dig up photos.
