February 01, 2025, 01:54:54 AM *
Author Topic: Mini Bike Suspension?  (Read 1377 times)
GregP
« on: April 03, 2009, 06:23:40 PM »
Is it ill advised to mount a shock upside down/reversed?
Got an Ishock (Ohlins of mini suspension Grin ) for my daughters TTR90.  The shock is specific to a CRF50 but the length and spring rate are perfect for the TTR.  The shock does not fit unless I turn it "upside down".  It is actually reversed as the shock is almost parallel with the ground when mounted.
The shock seems to function fine in this position as well.
Thanks
Don't expect much and you won't be disappointed.
manwithgun
« Reply #1 on: April 03, 2009, 10:41:51 PM »
I actually run an inverted Ohlins shock on my downhill rig.   I've never seen a modern shock that is angle dependent.  I have heard arguments that the lighter end (usually the shaft) be mounted to the swingarm to reduce unsprung mass but ....................
I ride both kinds,   Country, and Western.....
GregP
« Reply #2 on: April 04, 2009, 05:22:47 AM »
Thanks for the info.  It feels normal so. . .
Gus Duc
« Reply #3 on: April 04, 2009, 05:31:07 PM »
Yeah what the heck.... it's only your daughter Grin
