January 10, 2025, 08:14:16 AM *
Author Topic: Aftermarket spark plug wires  (Read 1230 times)
Chchadder
« on: April 09, 2009, 10:04:23 PM »
Anyone have a preference between aftermarket spark plug wires?  Thinking of going the Magnecor route, but not sure if they're really worth the extra $20 or so over NGK.  The new plugs will be NGK Iridium's by the way.  Any thoughts would be appreciated.
09 Triumph Daytona 675 - Rocket -
07 695 Custom Dark - Sold -
This motorcycle is simply too goddamn fast to ride at speed in any kind of normal road traffic unless you're ready to go straight down the centerline with your nuts on fire and a silent scream in your throat. ~Hunter S. Thompson
supertjeduc
« Reply #1 on: April 10, 2009, 12:36:06 AM »
I bought some red NGK's and i like them ,they fit (unlike the ones i had before which were to thick)
EEL
« Reply #2 on: April 10, 2009, 05:38:00 AM »
If you're going w/ NGK's and new wires, you might be able to open the gap on your plugs a little larger than spec. I've been reading up on this too. Specis .6 - .7 mm on most monsters you could probably bump up to .8mm without looking back.
Here's some research that will help you and a lot of others who need to understand this dark art.
http://ducati-upnorth.com/tech/ignition.php
Norm
hurricanemotorcycles.com
« Reply #3 on: April 10, 2009, 07:31:36 AM »
Tons of good ones at most auto parts stores these days, BUT, if you want the "best", go with the Magnacore.
