help get magic marker off my exhaust
Started by tristantumble, May 16, 2008, 07:07:33 AM
CapnCrunch
IsoPropyl alcohol, will take off even permanent marker
tristantumble
thanks for all the tips, will give it a try later and post on the outcome. i will keep an eye out for the little bugger and teach him/her a lesson on what motorcyles sound after bed time  [evil]
07.695 (sold)
07. sport 1000 biposto
lazarus7
"...the greatest artists indulge in a 'culpable rivalry' with God."     Stanislas Fumet
CapnCrunch
Quote from: tristantumble on May 16, 2008, 11:09:43 AM
Careful with the IPA, it's really flammable. make sure everything is cold. It evaporates quickly though so wating a minute after you use it should do you fine
printman
QuoteYou also may want to try one of those Mr. Clean "Magic Eraser" pads.....I am constantly amazed at what these things can clean and remove, most recently headlight lens fog-over and gunk....  waytogo
I would try this also before trying any harsh chemicals. these things clean so well. I am always amazed at what is removed even after using chemicals.
give a try first
I'll update this later at a convenient time Thank you for tuning in.....
mstevens
Dry erase markers do a good job of removing permanent marker. Just color over the original with the dry erase then wipe it off. This will usually screw up the dry erase marker, in case you were hoping to use it for its original purpose.
Alcohol will dissolve Sharpie quite easily and won't shine your dull cans or dull your shiny ones as abrasive products might do, in case you don't have any dry erase markers around.
Quote from: tristantumble on May 16, 2008, 07:07:33 AM
I park my bike in my backyard, but i guess the neighbors kid thought it would be fun to draw on the lower part of my exhaust with black magic marker. Its on the tube before the main exhaust part. any tips of getting this stuff off? ugh.
Asshole!
Refer to DML.."Stupid kids" and "stupid kids revisited"!
