January 31, 2025, 09:01:04 PM *
News: Please Help
Author Topic: 696 won't start right away  (Read 2283 times)
Duki09
« on: April 11, 2009, 07:05:58 PM »
The weather here around Phoenix isn't  cold, but my new 2009 Monster 696 is hard to start after it has been sitting for a few hours even when the outside temps were 70-80 degrees.  I have to start it while either giving it some throttle or set the idle lever on high for a minute. If I don't the engine will cut off out if I just try to start it and take off.
After the bike is running a minute or two, it runs just fine.
Is there a problem with my 696 if the engine needs to be warmed up a little even in moderately warm weather?
pennyrobber
« Reply #1 on: April 11, 2009, 07:34:43 PM »
The fast idle lever is there for this very reason. If your bike is new, it will probably get better after it is broken in a bit more.
Duki09
« Reply #2 on: April 11, 2009, 08:29:07 PM »
I thought the fast idle lever was there for cold weather starts.   Is 70- 80 degrees considered cold?  Well, maybe in AZ where the temps are over 100  half of the year,  but c'mon.
Hopefully it is just needs to be broken in more like you mentioned.  It only has about 400 miles on it.
Dietrich
« Reply #3 on: April 11, 2009, 10:00:55 PM »
Cold start as in the motor is "cold", as in not warmed up.  It'll need a little help most of the time, but should warm up pretty quickly.  If you don't need the lever turned very far you should be able to start riding and turn it off after a couple minutes.
hcomp
All this time I wondered what it was like to have a
Nothing to see here
« Reply #4 on: April 12, 2009, 03:43:31 AM »
I own a 696, live in Chandler and this is normal.  If the bike is cold it will not run very nicely until there is some amount of heat in the motor.  If you have not had your 600 mile service yet, they sync the throttles and change to synthetic oil during that service.  Trust me, until you reach 2000 miles the bike will not feel broken in.  That's when the bike finally felt perfect for me.
« Last Edit: April 12, 2009, 02:35:40 PM by ryanracer » Logged
にもかかわらず、私の車は本当に速いドライブ、私は女性の生殖器のようなバイクに乗る
Duki09
« Reply #5 on: April 13, 2009, 08:30:38 PM »
Thank you all.    I thought maybe something was wrong with my Ducati, but I guess everyhting is normal and just needs to be broken in a bit more.
Monster Dave
« Reply #6 on: April 17, 2009, 10:20:53 AM »
They change to synthetic oil at 600 miles???
Why not just start out with it!!
triangleforge
I'm just a guy. I'm no
2000 Cagiva Gran Canyon
« Reply #7 on: April 17, 2009, 10:27:15 AM »
The explanation I've always heard -- for any brand-new or newly rebuilt motor, not just Ducs -- is that a certain, very tiny amount of wear in the first hundred or two miles is a good thing, allowing the moving parts to fully match up with one another. Full synth oil supposedly inhibits the desired breaking in during the "break in" period.
