January 10, 2025, 08:13:17 AM *
Author Topic: Rizoma Bars @ Genmar risers  (Read 1381 times)
Gramps
"Ride your own road in life don't follow"
« on: April 13, 2009, 09:27:41 AM »
 Huh?  Right now I have the stock bars on  my 2008 S2R 1000 with the Genmar risers. I have heard that the Rizoma bar will give me 1 inch up and one inch back compared to the stock bar? Will the Rizoma bar work with the Genmar risers? Thanks for any help on this
                                  Gramps [moto]
S2R 800 '07
« Reply #1 on: April 13, 2009, 09:49:50 AM »
The Rizoma bars are just over two inches taller than stock bars. The added sweep is somewhere in the one inch area. Both measurements will be a little different depending on how you rotate the bars.
Usually, your stock lines and wires will be long enough with the Rizoma OR the Genmars, but even then some rerouting may be required. Combining the two will probably require some new longer items.
My FHE is with the SpeedyMoto 20mm risers - the only issue was a tight fast idle cable, but didn't have to reroute.
The Rizoma bars might give you a much more comfortable wrist (sweep angle) and be tall enough?
I'm sure PJsParts will know more about the Rizoma and if you can install without issues. Or, of course, some of the guys here bow down
geoffduc
18 till i die
« Reply #2 on: April 13, 2009, 12:16:53 PM »
Gramps i've played around with the handle bars on my monster and after trying brutale,rizoma and stock with risers i have found that rizoma with out risers are spot on and if you carefully reroute the cables and pipes they are long enough to reach and pose no problems.  waytogo
 coffee
2015 scrambler FT
2009 monster 1100s
