What is this?
Started by TreyRiser, April 15, 2009, 07:37:22 PM
TreyRiser
I was looking at my delicious monster and i was wondering what this gray plastic eyesore is in between the frame above the oil cooler? And can i remove it or will zombies eat my face?
I am gonna have my kicks before the whole shithouse goes down!!
minnesotamonster
Don't do it or your face is done for!
No seriously, I'm not exactly sure but I believe they are little "pods" that take in "still air" lots of people take them off then stick the tubes up into the engine cavity somewhere. I've done it and haven't noticed any problems/changes.
2004 S4R
1998 Honda F3 (Track)
2001 M600 (Now the Wife's)
Those are vent pods. Get rid of that shit.
TPO Parts even has a tube kit so you can reroute the hoses the hell away from there. Then again, if you want to keep them I suggest you get them painted the same color as the frame.  Your call.
At this point, I suspect you also still have your emissions canister. Search about that, then remove those parts from your bike as well.
TreyRiser
so i pulled out the plastic and jammed the tubes up underneath the battery and zipped tied them in...that should be fine right?
Should work great. if your carbs stutter any, you know that the wind is creating pressure there, and you need to wiggle them somewhere else.
TreyRiser
sweet, thanks for the help and timely responses... good day to you sir [clap]
also, and again, if you feel like spending the few pennies to pick up the y-adapter and single hose line from TPO parts, this allows you to only really think about one hose end to hide. Not that you need to do this, mind you, but its there if you like.
Mine's been without those pods for about 9,000 mi, no problems once I got the hose situated out of the flow of the air. Since that has happened, I've also opened the air box, and still no ill effects. Ridden in the rain, no problems.
causeofkaos
Quote from: ato memphis on April 15, 2009, 07:51:38 PM
While your at it make sure you rip that label off your mattress !!!!!  [cheeky]
Favorite convo i read on this board
"PICS OR IT DIDNT HAPPEN"
"F**K U IT HAPPENED"
Suzuki Blvd M109R " Sliver " = assassinated by cager
PW 696 " Pearl " = traded in
M1100 " Loki " = Viking God of mischief ( Goddess in this case )
Life is not a journey to the grave with the intention of arriving in a pretty pristine body, but rather to come in sliding sideways all used up screaming F*CK YEAH WHAT A RDIE!!
