Stripped alternator cover bolt holes
Started by erkishhorde, April 15, 2009, 09:13:08 PM
erkishhorde
So I finally got around to taking off the alternator cover to tighten up the starter motor mounting bolts that I suspect was causing a very small oil leak. But when bolting everything up I found a 4 bolts that had stripped holes.  :-X 2 of them I can get a longer screw to grab onto threads deeper inside the hole but the 4th (behind the clutch slave) can't be helped much. I got it just barely snug with a screwdriver and don't have to worry about it backing out since it's behind the slave. Hopefully it doesn't leak. I don't think it will.
Anyway, the longer bolts grabbing more thread  in the other 3 bolts won't last long I'm thinking. Knowing me I'll likely strip them the next time I take them off. I can be a bit ham fisted sometimes. [roll] Any suggestions on fixing these stripped holes so I know what to do when they finally give out?
Quote from: erkishhorde on April 15, 2009, 09:13:08 PM
If the cover was off before the bolts may have been shuffled and some may not be long enough.  I think the one behind the slave will be problematic since the slave tries to move that part, but you might be lucky.  If it leaks there the leak should not be bad, though.
If there is enough meat around the affected holes these are the answer:
http://www.timesert.com
wiggy_nz
Heli Coil will do the trick.  I have used them before on a Honda motor.
Brendan
Current bike - 2005 S4R Monster
Sold 1997 Red 900 Monster
Sold 1999 Yellow 750 Monster
Can not keep the silly smile off my face when using my Monster :-)
amcloud
Quote from: wiggy_nz on April 16, 2009, 01:06:41 AM
Brendan
Don't use a helicoil.  Use a time-sert.  They are a much better solution, and if installed correctly, stronger than the original threads.  Google them.
M696 - sold, M1100s - gold Speedy kukri pressure plate, black Speedy halflife cover, Pazzo shorty racing levers, 14 tooth front, CRG ls, Speedy sliders all around, Leo Vince exhaust.
Quote from: amcloud on April 16, 2009, 06:19:17 AM
Time sert is a great product, but for this application I think I'd use a helicoil too.
We're talking about a 6 mm screw, not a spark plug or cylinder stud.
Quote from: ducpainter on April 16, 2009, 06:25:07 AM
+1, cheaper too
those screws are not under a lot of torque, just a bit
brad black
the one behind the slave is the most important as the slave is trying to pull the cover off the cases every time you pull the clutch in.
the helicoil kit is expensive if you have only 1 to do, but if you're doing 4 it's not so bad and they're mighty useful.  make sure you get the right size drill too and use some crc, wd40 or the like when drilling and tapping the thread.
Brad The Bike Boy
http://www.bikeboy.org
erkishhorde
Heh, the Helicoil site likes to flash around that it's a US product but payment options are in USD or Indian Rupees...  [roll] I think I'll be researching this a bit. I've got some time... I think. I don't plan on fixing it just yet.
TIME-SERT.
Heli-coil ******only****** if you have to.  Nevermind the bolt size/thread/torque value.
This is my opinion, YMMV.
Langanobob
I *think* Heli-coils may use a slightly smaller drill bit and tap.  If that's true, then I'd go with Heli-coil since there isn't a lot of extra meat in the threaded area.  Properly installed, they are going to work just fine.  But if the tap size is the same, either method will work fine.
I think that just  like the global warming issue, this one is split right down political lines.  Everyone who insists Time-Serts for this one voted for McCain and Heli-Coilers went with Michelle's husband.   See - if you don't agree with me on Heli-coils for this particular application I'll just get this thread locked.  ;D
TimeSerts take smaller drills and taps than Helicoils.
erkishhorde
Lol, the timesert instructional video has a sales pitch at the end that says they have inserts with thicker walls in case you need to fix a helicoil that failed.  [laugh]
I've got the whole kit, and inserts too.  ;)
erkishhorde
Hmmm... This kind of repair is most likely done with the cover off, yes? Me thinks Nick will be seeing me the next time I need an oil change. Hmmm... I should note which ones are damaged now before I forget. As it is I can only remember 3 of them... Coulda sworn there was a 4th...
