April 28, 2024, 10:24:43 PM
2002 S4 with tach messed up
Topic: 2002 S4 with tach messed up (Read 1467 times)
mattb
May 16, 2008, 10:14:26 AM »
My tach now points at 10K when I'm at an idle -- the movement seems normal for the most part... Anyone had this issue and/or know how to fix it?
thx
Matt
Re: 2002 S4 with tach messed up
May 16, 2008, 10:19:30 AM »
Generally, that's a 'replace it' fix.
Need to buy new, or virgin used unit, as the immobilizer is an issue.
Some folks have opened 'em up and re-indexed the needle, with varying success.
I'm pretty sure it's a cut-it-open deal, so not the greatest scenario.
Rameses
*Your Mom* has a Hypermotard
May 17, 2008, 01:51:24 PM »
Sometime last year I had my instrument pod torn apart for something.
I accidentally bumped one of the needles (can't remember if it was the speedo or tach).
When I plugged it back in, it re-zeroed the first time I turned the key on.
Since it's simple to do, you might want to try unhooking and then reconnecting the battery.
