January 10, 2025, 11:56:43 AM
Please Help
S2R fork diamater (not the 50mm)
Topic: S2R fork diamater (not the 50mm) (Read 1138 times)
xcaptainxbloodx
April 21, 2009, 11:35:39 PM »
Im getting clip ons and thinking about a new headlight, to make it easier I want to get new headlight ears so I can lower the whole setup.
I know the upper part of the fork tube (where im attaching the clip ons and where it meets the top triple) is 50mm but what about the lower part?
and one step further, anyone got a source for headlight ears that would fit that lower,larger section of fork tube?
rockaduc
Re: S2R fork diamater (not the 50mm)
April 22, 2009, 01:31:31 AM »
pretty sure it is 54mm
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris, you may be only seconds away from death.
herm
April 22, 2009, 03:39:33 AM »
something like this?
not sure who carries these, as i got mine used from a member on TOB.
you might check
these guys
. they carry all kinds of "streetfighter" bling
xcaptainxbloodx
April 23, 2009, 04:08:05 PM »
I think I need one that clamps to the tube and then the ear can swivel upwards.
Im mounting clipons and may get a new headlight at some point so I figure get the ears then I can lower the stock light, ditch the stock bracket and then mount my gauges under the triple with some bolts.
