Brake Shudder
Started by Schwanger, May 16, 2008, 03:42:33 PM
Schwanger
When I brake hard and run over a bump I get a horrible shudder in the front end that progressively gets worse until I stop of let off.  I've been fighting this for over a year.  I have tried cleaning the brakes, including the rotor buttons, and increasing the rebound and compression damping.  I have only recently started messing with the forks and I only increased the damping by 1 click on both rebound and compression.
I need some help.  Any ideas?
Quote from: Schwanger on May 16, 2008, 03:42:33 PM
I think you need to properly bed in your brakes.
Check these two threads....
http://braketech.com/techtalk_article.php?id=4
http://braketech.com/techtalk_article.php?id=8
Have you looked at your steering head bearings?
Quote from: Speeddog on May 16, 2008, 03:53:26 PM
Is your front suspension bottoming?
Schwanger
I don't believe that the suspension is bottoming out.
I'm going to check the head bearings, they might be loose.
