need help with dead instrument cluster light
Started by jimmygomk3, April 22, 2009, 11:21:30 AM
jimmygomk3
I noticed last night that the top half of my speedometer lost its backing light... the bike in question is a 2001 M750 with the second generation gauge (speedo + tach) before the needles swept with the FI bikes...
does anyone have experience digging into the cluster?  difficulty of replacing the burnt bulb?  DIY anywhere?
Thanks,
Jeff
Chchadder
HeMan pulled his apart and redid his LEDs just recently.  Thread should be pretty easy to find.
09 Triumph Daytona 675 - Rocket -
07 695 Custom Dark - Sold -
This motorcycle is simply too goddamn fast to ride at speed in any kind of normal road traffic unless you're ready to go straight down the centerline with your nuts on fire and a silent scream in your throat. ~Hunter S. Thompson
the older guages (from what i hear) have a incandecent bulb in the unit, so its a simple swap. the only issue becomes cracking them open, the older gauges AFAIK are a PITA to crack open.
