Tank vent hose?
Started by DarkStaR, April 23, 2009, 06:58:45 PM
DarkStaR
So I took my bike to a "VERY RESPECTABLE SHOP" for a bunch of scheduled and non-scheduled maintenance stuff.
I noticed that they removed the tank vent hose.  When I asked about it, they said I didn't need it.  After thinking about it, I don't see a need for it either...
With the charcoal canister removed, does the tank vent hose serve a purpose?
Quote from: DarkStaR on April 23, 2009, 06:58:45 PM
No...
You still need the drain hose though.
Many shops connect the two with a Y to eliminate the possibility of fuel dripping on a hot header.
DarkStaR
Quote from: ducpainter on April 23, 2009, 07:03:24 PM
No...
Is it possible for fuel to drip out of the tank's vent?
I have a plastic tank if it makes any difference...
Quote from: DarkStaR on April 23, 2009, 07:13:35 PM
If you raise the tank with too much fuel in it or overfill it enough so expansion causes it to come out.
The plastic tank has no bearing on it.
billruiz
+1 on the expansion thing. I freaked when I saw a copious amount of fuel under my bike after filling up and riding 1 mile back to my garage.
EEL
If you accidentally overfill your tank and go around a turn at a high lean it may spew out. Best to put a Y like previously mentioned and route down to below the bike.
I've had it spew before on my bike. Combination of a hot summer day, and filling the tank too high and going for a ride in the hills.
