January 10, 2025, 01:09:07 PM *
Author Topic: Cutting carbon Termis  (Read 2506 times)
grandpa nate
« on: April 27, 2009, 08:26:55 PM »
This past weekend I saw a pregnant dogen S4RS with cut down Termis....i want to do the same but am too much of a chicken shit to just jump into cutting my pipes.  Just kinda lookin for some pointers so i might not totally make the beast with two backs this up.  Thanks
that is all
carry on
MAXdB
« Reply #1 on: April 27, 2009, 08:45:41 PM »
hey grandpa.. it's very easy really. I believe tafatnomos did it too. Here's how I did it although I'm sure there are much quicker easier ways to do it:
1) measure where you want to cut the pipes while it's still on the bike.. maybe make a note with some masking tape
2) take off both cans
3) drill out the rivets so you can slide the carbon fiber off
4) take off the caps
5) take off the carbon fiber
6) Put masking tape on the area where you will be cutting the carbon fiber.. use dremel.. measure twice, cut once
7) cut the steel wool and fiberglass packing with some good scissors and cut the perforated tube thats inside with a hacksaw to the same length as the carbon fiber
Cool slide the carbon fiber over the fiberglass and align the lower holes and rivet on and then drill holes in the new top part of carbon fiber so you can rivet the end caps on
9) rivet the end caps back on
10) and enjoy.
This may help also--> http://www.r1-forum.com/forums/showthread.php?t=211887&highlight=shorty+pipe
I'll check to see what drill bit and rivet size I used and get back to you. oh BTW thanks for the stickers
« Last Edit: April 27, 2009, 08:55:28 PM by MAXdB » Logged
mojo
'99 M900S
« Reply #2 on: April 28, 2009, 02:48:59 PM »
READ THIShttp://www.fullforcerc.com/CarbonCare.htm  Some of it applies more to R/C cars, but you will get the idea.
Carbon fiber is nasty stuff because of the dust being so light and getting everywhere.  If you have access to a wet saw, that would be the way to go waytogo
« Last Edit: April 28, 2009, 02:50:30 PM by mojo » Logged
Some people are like slinky's.  They serve absolutely no purpose, but they always bring a smile to your face when you push them down the stairs.
MAXdB
« Reply #3 on: April 28, 2009, 06:24:39 PM »
you should use a 3/16" drill bit to drill out the rivet and then use 3/16" short rivets when putting everything back together. Show us the final product if you go through with it  waytogo
grandpa nate
« Reply #4 on: April 28, 2009, 09:13:24 PM »
will do!!!  waytogo
