January 10, 2025, 07:05:54 PM *
Pages: 1 [2] 3   Go Down
Author Topic: Other Ducatis' wheels fit on the 696?  (Read 13422 times)
mrplease
« Reply #15 on: April 29, 2009, 07:04:51 AM »
michelin pilot power are a nice sticky tire. i plan on getting the pilot power 2 ct next time.
i'm not sure if these are heavy or light tires though, if that matters to you...
loves ze desmodromics.
« Reply #16 on: April 29, 2009, 10:53:23 AM »
Powers are very much overkill for a street ridden 696. Roads or Road 2's are more than you'll ever need and people even use these for trackdays, and actually have some wet weather performance, and unlike the Powers, won't square off really fast which seriously undermines turn-in.
mrplease
« Reply #17 on: April 29, 2009, 11:17:42 AM »
yeah i've heard good things about the michelin pilot road tires. i heard they also have a longer life than the pilot power ones do. they look pretty cool too!
pjfa
M696 pjfa Edition & 900SL III #643
« Reply #18 on: April 29, 2009, 11:55:11 AM »
Because I thought you would doubt me:
http://www.ducati.ms/forums/showthread.php?t=29854
Nice.
It would be great if we all get the last info/weights of last generation tires  waytogo
So, anyone want to start?  Grin
« Reply #19 on: April 29, 2009, 12:29:50 PM »
Road 2's still have the long life, but with very sticky edges for grip to rival the Powers. My power squared off on me way too quickly. Powers will only be on superbikes for me from now on.
pjfa
« Reply #20 on: May 01, 2009, 02:34:28 PM »
I got a used ST rear wheel for my 696 and after trying to fit the thing and having a battle I decided to do some measurements.
Lo and behold the ST wheel Hub is 5 mm wider than the 696 wheel, so now the left side spacer and caliper carrier are in for some machining down, other than that I can`t tell you much bang head
The DSS wheels of all the fuel injected models and the ST series bikes are the same, wether 3 spoke or 5 spoke, I have measured them all, so there are no bolt on replacement, some machining will be required.
Any update info???  coffee  waytogo
peanut_man
« Reply #21 on: May 01, 2009, 08:17:41 PM »
 Tongue
So... OK, I guess it's not that easy to get wheels from a different bike to fit the M696.  Too bad.
2005 Buell XB12S | 2006 Honda CBR 600RR | 2005 Ducati Multistrada 1000DS | 2009 Ducati Monster 696+
Big Troubled Bear
The wrong side of normal
98 m900 sold, Red 696
« Reply #22 on: May 04, 2009, 12:22:49 AM »
Nope not yet bang head
pjfa
« Reply #23 on: May 05, 2009, 09:16:37 AM »
Hot News  Evil
Wheel will fit without any machining  waytogo
I´m just waiting for confirmation from a Spanish. He told me already 3 guys with M696 install the rear wheel from a Ducati ST.
Only 3 little things to do and the wheel fit as standart  bow down
He sent me a e-mail with the "How.to"
One - remove a rubber bushing (I think is one of two rubber things in the carrier of the M696)
Two - invert the aloy spacer (I don´t know if the left one or the rigth one  Shocked )
Tree - remove a aloy spacer
When I have all the info I will inform you all.
So, go for the ST rear Wheels  waytogo
peanut_man
« Reply #24 on: May 05, 2009, 12:05:01 PM »
Hot News  Evil
Oh, don't forget the pics!!
Big Troubled Bear
« Reply #25 on: May 06, 2009, 02:19:58 AM »
Hot News  Evil
Please let me know as I have just sent my standard wheel in for widening, as I didn`t want to machine any parts and the widening is only gonna cost me 140 dollars waytogo
pjfa
« Reply #26 on: May 06, 2009, 03:48:55 PM »
@ Big Troubled Bear - I will  waytogo
For keeping the issue hot, here a view of the technical manual...
I guess the rubber part to take out will be the number 27;
Maybe invert the aloy spacer number 22 with the 25 and... maybe take off one aloy spacer number 17 (they are two)  Grin
Here is my bet  laughingdp
« Last Edit: May 06, 2009, 03:50:45 PM by pjfa » Logged
pjfa
« Reply #27 on: May 07, 2009, 04:59:00 AM »
It seems I´m not a great gambler  laughingdp
So... number 27: off
Number 4 near carrier: off
Other number 4 near disc: reverse it
But, I need a final confirmation on this issue because the info was:
27 and 4 out and turn the other 4  Grin
So, still waiting for news but, we are close  waytogo
« Last Edit: May 07, 2009, 05:00:35 AM by pjfa » Logged
pjfa
« Reply #28 on: May 07, 2009, 10:26:08 AM »
Ok, latest news  Grin
The mood should be as my last answer:
- remove part 27 and 4 (carrier side)
- reverse part 4 (disc side)
That´s it  waytogo
So, I think I go for the BT 016  coffee
But before, I have to paint the rim black as the front whell.
Anybody knows the color code?
« Reply #29 on: May 07, 2009, 02:33:01 PM »
Probably ought to powdercoat. Also, go on and get a 90 degree valve stem for the rear too, it makes checking air pressure much easier.
Pages: 1 [2] 3   Go Up
