January 10, 2025, 07:08:30 PM *
Pages: 1 2 [3]   Go Down
Author Topic: Other Ducatis' wheels fit on the 696?  (Read 13423 times)
peanut_man
« Reply #30 on: May 07, 2009, 06:37:43 PM »
Ok, latest news  Grin
The mood should be as my last answer:
- remove part 27 and 4 (carrier side)
- reverse part 4 (disc side)
That´s it  waytogo
So, I think I go for the BT 016  coffee
But before, I have to paint the rim black as the front whell.
Anybody knows the color code?
pics?
2005 Buell XB12S | 2006 Honda CBR 600RR | 2005 Ducati Multistrada 1000DS | 2009 Ducati Monster 696+
Big Troubled Bear
The wrong side of normal
98 m900 sold, Red 696
« Reply #31 on: May 08, 2009, 03:37:22 AM »
It seems I´m not a great gambler  laughingdp
So... number 27: off
Number 4 near carrier: off
Other number 4 near disc: reverse it
But, I need a final confirmation on this issue because the info was:
27 and 4 out and turn the other 4  Grin
So, still waiting for news but, we are close  waytogo
I don`t want to sound stupid Huh?
But number 4 is a bearing, can`t ride without it Huh? bang head
pjfa
M696 pjfa Edition & 900SL III #643
« Reply #32 on: May 08, 2009, 04:29:45 AM »
Yes, is a bearing but, the carrier (21 and 19) will do the work as the parts 22, 17 and 20.
pjfa
« Reply #33 on: May 19, 2009, 04:41:47 AM »
Hi All,
Just come back from the shop  coffee
Fresh news...
The mesurements are in cm  Grin
Size of wheel from M696 is 22,3cm (all included - as you take it off from the swingarm)
To fit a ST rear wheel into a M696 bike:
- remove 27;
- machine a washer with:  inner diameter 30, outer diameter 33 and 1,5mm large (to equilibrate the missing part 27 and avoid having the rear sprocket flange with some play);
- keep the part 25 for when you sell the M696 with 4.5" rear;
- part 22 take place of part 25, and put the new washer in the part 22.
Hope you understand the explanation, is very simple to do and only need a new washer ONLY if you want to avoid some play of the rear sprocket flange.
Next week I hope have all done (washer, wheel paint black, marchesini stiker, red wheel stripe and 180/55-17 BT 021)
« Last Edit: May 19, 2009, 04:46:58 AM by pjfa » Logged
w7ck7d
The DUCtOr
« Reply #34 on: May 22, 2009, 02:51:16 PM »
nice..im thinking about doing this ..maybe cheaper than the 5 spoke aftermarket rims
09' 696 Black
94' BRONCO 5.8 EB
pjfa
« Reply #35 on: May 28, 2009, 03:25:08 PM »
Washer is ready.
I will pick up the wheel next monday at painting shop.
Carbon Trader already sent me the Marchesini stickers and the wheel stripe arrive soon  coffee
« Reply #36 on: May 28, 2009, 09:55:31 PM »
Washer is ready.
ok for all you people living in America... name that coin Wink
causeofkaos
« Reply #37 on: May 29, 2009, 07:34:03 AM »
im gonna guess 1 euro
Favorite convo i read on this board
"PICS OR IT DIDNT HAPPEN"
"F**K U IT HAPPENED"
Suzuki Blvd M109R " Sliver " = assassinated by cager
PW 696 " Pearl " = traded in
M1100 " Loki " = Viking God of mischief ( Goddess in this case )
Life is not a journey to the grave with the intention of arriving in a pretty pristine body, but rather to come in sliding sideways all used up screaming F*CK YEAH WHAT A RDIE!!
pjfa
« Reply #38 on: June 08, 2009, 04:47:44 AM »
peanut_man
« Reply #39 on: June 08, 2009, 06:05:37 PM »
Hmmmm... well, certainly detailed pics, but is there any procedure associated w/ those pics?  Cheesy
pjfa
« Reply #40 on: June 09, 2009, 01:05:18 AM »
Yes there is  waytogo
So, this must be a "HOW TO"  coffee (I already open a new thread: http://ducatimonsterforum.org/index.php?topic=25054.0)
First
Remove the "old wheel" (13) Grin
Switch the disc (15) to the "new" wheel.
Then, remove the sprocket carrier (21) and take off the rubber thing (27) and the washer (25) Grin
Insert the washer (machined with inner diameter of 30mm and 1,5mm wide - the outer diameter is 33mm but can be more) inside the part 22. Keep the coin to take a coffee after the assembly  coffee
Now, the part 22 (standart comes from inside to outsite) will take place in the sprocket carrier (21)
Pic a nice tire and mount it  Grin
(In my case a Continental ContiSportAttack)
Put the wheel on place and... That´s it  waytogo
Have fun  [moto]
« Last Edit: June 09, 2009, 01:12:00 AM by pjfa » Logged
Pages: 1 2 [3]   Go Up
