Quick question about midpipe
Started by aa4111, May 16, 2008, 11:14:20 PM
aa4111
This is a spark midpipe from desmoworld. Is the bung pictured for an o2 sensor or a regular port that is plugged except when being tested/tuned at the dealer??? In other words, is this the for an S2R800 or S2R1000?
I can't tell from your photo, but if the bung is in an area affected by both cylinders, is rather large and there is only one it is for an O2 sensor.  If there are two of them, they are small in diameter and are before the crossover , they are for an exhaust analyzer.
corey
That looks like an o2 sensor bung. if you don't have an o2 sensor, you an easy find a metric bolt that will plug that bung.
q monster
i've just ordered this set up for my 2008 S2R1000 - the midpipe takes the O2 sensor. Talk to Chris at Desmoworks. I've also ordered a set of black stainless cans so i can route the headers one on either side of the bike just under the seat - i want to see the rear tyre sitting there with the unilateral swing arm. Both should arrive in the next week or so - i'll post a pic when they're fitted.
q monster
2008 S2R1000 changed - spark headers and tail cut done, rizoma grips indicator lights and clutch cover titax levers, DP ECU, open filter, ...... maybe stop then............. nah think i'll add rizoma rearsets and their conical handlebar is f..hot... and then i need to get rid of those mirrors....
aa4111
Yes, it turns out it is an o2 sensor bung. I do not have the pipes in front of me and wont for a bit so I couldnt inspect in person. You can just barely see the tip of the horizontal cylinder gas analyzer port in the long section of the midpipe. The vertical cylinder port is on a short piece of pipe that you retain from your stock pipes. So it appears I wont lose anything if I just plug that hole... as long as everything still fits the same... which it will... I think.... Thanks for the help everyone
