Tag and Light bracket mod
Started by Latinbalar, May 01, 2009, 07:24:34 AM
Latinbalar
So when I did the first bracket it was ugly made of super thin material and kept hitting the rear wheel on large bumps. So came the time for a new one. I found some good sized gauge stainless material. Then came the measuring, planning and lots of inspiration. And presto the new mod. then sat back and had a  [drink]
And since I know alot of people in the right places I can have these laser cut on a mass production scale and machine bent. So if there is enough instrest let me know.
Nice work  [thumbsup] [thumbsup]
If you're not already on it, may I suggest these as combined plate lights and plate bolts?
http://www.customdynamics.com/illuminatorz_licence_plates.htm  (scroll down a bit)
If you go for these, remember to slide the washer and nut on to the wire before connecting ;)
Latinbalar
QuoteNice work
those are cool, but i have the clear alternative light.
Quote from: Latinbalar on May 01, 2009, 11:36:12 AM
:) Ok, to me it looked like the bracket blocks the integrated plate light. (Since this bracket seems to be a little longer than most others)
