Bar Slider or I must be stupid
Started by MsTek, May 02, 2009, 08:31:58 AM
MsTek
I thought this morning I'd swap out my mirrors and put in the new bar end sliders on my '06 S2R.  Easy, right?
Well... I don't know what I am doing or these are the wrong size.  I am not sure even where I ordered them from anymore.  They are Rhino Moto sliders.  They seem to be too big to get into the tube.
Suggestions?  I got the wrong ends?  I shouldn't use tools?  What?
Thanks!
"Do something each day that scares you..."
Many/most RhinoMoto bar end sliders won't work (too thick). They have one S2R/S4R/848 specific model for your tapered aluminum bar, which has inner diameter of only about 14mm. It's very possible the vendor sent you a wrong one, if they aren't used to Ducati or not awake at the time.
So, I think, if you specified your bike and they still sent you the wrong ones - they should pay the coming double return/shipping cost.
You're not stupid, you're just learning to double check everything you do ;)
Which mirrors did you get?
MsTek
Quote from: stopintime on May 02, 2009, 08:47:48 AM
Yeah, I sent them an email specially asking if they would fit and he said yes.  Guess I have a refund coming.  Damn.  Now I need to wait until that comes and I can order some that fit.  There is no way that plastic is going to go into that tube but I wanted to be sure I wasn't being a retard.
CRG bar end mirror.
psycledelic
The first set I had were also to big to fit into the ID of the stock Magura bar.  I took the slider insert to work and had it turned down a little to make them fit.  If you can't return for the right part, resizing might be an option.  Just make sure not to have to much taken off.
06 S2R800 - the wife                         [Dolph]
04 999s - the mistress
bmonty72
#4
I bought a pair of used Rhino Bar End sliders form a member here....Turns out, that member had a 696 not an S2R (like mine).  I contacted Rhino and they said, just send them in an we'll turn them down on a lathe for no charge.  When he got them, he said they were too far gone and sent me a set of new internals for just the cost of those parts.  They were SUPER Easy to work with and IMHO a GREAT customer service company.
http://www.rhinomoto.com/contact-us.html
email them, I'm sure they will take care of you.  Good Luck!!!! also I love my Rhino Sliders with CRG mirrors!!!!!
MsTek
thanks for the tips.
I'll try the place I ordered from first since they told me these would work (I was very specfic about the bike I have)
Then I'll go to Rhino.
Thanks again!  =)
