S*R kick stand on M800
Started by rkundrat, May 03, 2009, 03:23:35 PM
rkundrat
I picked an S*R kickstand to replace my bent stock one. Of course, the kickstand then touched the exhaust header in its retracted position. So I fabricated a stop to keep the stand from going up that last 1/4" inch and reasting on the pipe. I used a block on nylon, drilled and tapped the back side of the kick stand mount and attached with a small screw. Thought I would share for anyone wishing to use an S*R stand on an older Monster.
Outside of stand showing spacer
Back side of stand showing attachment of spacer
On the bike. barely noticeable, and just a little space between the stand and pipe
Italians have it pretty figured out...
2003 Monster 800s i.e.
Remus high-mounts • PCIII • Evoluzione slave cylinder • Tommaselli clip-ons • CRG & Pazzo levers • Sargent seat • CRG bar end mirrors
1992 Alfa Romeo 164S
Teutonics
Nice job.  I was going to weld a tab or something to do the same, but this is a simple, elegant solution.  Thanks for sharing!
Atlanta, GA - 2002 M900ie
