October 19, 2024, 09:48:25 PM
Please Help
Low price on Cycle Cat triples
Topic: Low price on Cycle Cat triples (Read 1728 times)
Mr Earl
2003 M800 Dark
May 08, 2009, 12:08:30 PM »
I found this link whilst looking for some clip-ons, and was amazed at the price on these Cycle Cat triples. FYI, I am in no way affiliated with Oncycles, ...yada yada. Have never ordered from this website before, but I wish I needed one of these triples as $90 seems worth the risk.
http://www.oncycles.com/browse.asp?department=clearance&category=billetaccessories&subcategory=tripleclamps
Leo Vince CF slip-ons, '01 SS900 fully adjustable Showa forks w/ST2 springs, rebuilt S4 shock w/Ohlins spring, 748 dog bone, Swatt clip-ons above the triple, Sargent seat, Duplicolor-Dark seat cowl, Rizoma grips, Techlusion TFI, SBK front fender, Evoluzione slave, BMC sport air filter, 14-tooth sprocket, Desmotimes caseguard, S2R side panels, Pantah belt covers, fake CRG LS mirrors, extra black zip-ties, right grip control imprint on tank, de-cannistered, Ducati Meccanica Bologna key ring
Spidey
Crashin' mofo
Re: Low price on Cycle Cat triples
May 08, 2009, 12:15:35 PM »
Oncycles used to be CycleCat (kinda).
Be aware that those triples are
only
for a superbike fork conversion (53mm diameter) on a monster. They won't work with stock monster forks (50mm/54mm diameter).
tankerbutt
May 08, 2009, 07:34:53 PM »
quick question, i have a '01 M600, the website says it will fit all 600's. i was under the impression that i have 50 mm forks, am i mistaking???
Ducatiloo
May 08, 2009, 09:14:58 PM »
Quote from: tankerbutt on May 08, 2009, 07:34:53 PM
You do have 50 mm forks. The triple found on this link is 53 mm to accommodate a SBK conversion which would use 53 mm forks. With your current forks this triple will not fit your bike.
750 SS 01
800 S2R 05 Aprilia RST 1000 futura
Ducatiloo
May 08, 2009, 09:15:57 PM »
Wish I had an older monster so I could take advantage of this deal
750 SS 01
scduc
May 09, 2009, 07:19:00 AM »
Yeah, those CC's are sweet. I had one on my 00' 750. Now my option is SpeedyMoto. Their's are pretty nice as well, and with their new 3.5 rise clip-ons, I cant wait til I can afford them.
08' S2R 1K That was close damn near lost a $400 hand cart.
rgramjet
May 09, 2009, 07:31:22 AM »
Quote from: Mr Earl on May 08, 2009, 12:08:30 PM
I got the top triple clamp for my 2001 Cromo when I did the SBK conversion. One of the best deals Ive gotten on an aftermarket part.
Piece is flawless to my laymans eye except for a little "X" scratched on the underside.
-Sofadriver
Mr Earl
2003 M800 Dark
May 09, 2009, 08:57:00 AM »
Since these have 53mm bores, I wonder... has anyone shimmed their top triple? I'm about to install 900SS Showas on my M800 using the Monster top triple but will be using clip-ons. So I'm stuck with the ugly unused handlebar mounts. One of these CC triples with 3mm of shim might be a better setup. Could be fugly too, I suppose.
loves ze desmodromics.
May 09, 2009, 11:22:01 AM »
Quote from: rgramjet on May 09, 2009, 07:31:22 AM
I got the same thing a few years back from the Catshop or whatever they called it. It was listed as a "blem". Can't find a blemish on it, anywhere. It matches their clipons (which I also have) exactly and they were non-blem. Go figure.
tankerbutt
May 09, 2009, 12:23:06 PM »
Quote from: Ducatiloo on May 08, 2009, 09:14:58 PM
thank you sir
May 10, 2009, 07:09:18 AM »
Also of note, I believe the superbike conversion triples still use the small diameter hole for the frame (the third hole of the triple).
