Barnett Red Clutch Packs...Sticky after wash
Started by He Man, May 08, 2009, 04:10:38 PM
Does anyone use the barnett red plates and notice that they get stuck after you wash the bike with an open clutch cover? I dont spray water into it, but if it even sees water, they wil get stuck. ill have to open them up and wack the plates and maybe reset a few of them otherwise my bike will be stuck in 1st gear even with the clutch in.
This even happens with 4 springs!
Ddan
Quote from: He Man on May 08, 2009, 04:10:38 PM
After a ride in the rain, too.  I just start off and it comes out of it.
Ducati Monster Forum at
www.ducatimonsterforum.org
Ducnial
Yea, I've got one on a 996 and it will glued together if it gets wet and drys sitting.  I took it apart and noticed all the disc faces were imprinted with the friction disc pattern and crusty.  Looks like the friction material is somewhat water soluble?  Best suggestion is to either cover it up with a closed cover or be sure to run it dry immediately after washing.
Quote from: Ducnial on May 08, 2009, 05:39:37 PM
-----------------snip-----------------
That's the way to go.
oh well, didnt have the key at the time and i washed my bike, made sure not to hose that section, yet some how an hour later the thing is stuck again.
Any advantages from the barnetts to the OEM packs? i think im going to go with OEM next time around... ive heard some stories about barnetts not lasting that long.
DucHead
corndog67
it was her first real wash in 1,000 miles! cut me some slack! before that were just a bunch of rain showers.  :P
I dont know how much the OEM's cost but if they wear less then the barnetts its probably worth it, if its under 250. but at that cost i might as well try surflex or motowheels brand.
Quote from: corndog67 on May 10, 2009, 12:34:54 AM
What do you mean by "wash the bike"?
old rag, a bucket of water with dish washing soap and a can of Honda proshine.
