S2R800 race bike with pics
Started by killerniceguy, May 10, 2009, 01:11:21 PM
killerniceguy
Here it is.  The pics are not the greatest but after what seems to be about 11ty million hours the bike has made its track debut.  Here are the list of the modifications from stock:
•   SBK front forks from a 749
•   Ohlins steering damper (side mount, mounted upside down so it can be adjusted while riding)  This isn't a good pic of this but you can find many on the forum
•   All suspension set up for my weight
•   Speedymoto top triple/bottom is stock with 0.5mm shim
•   Speedymoto clipons
•   bar sliders
•   Speedymoto frame sliders
•   CRG levers
•   Rizoma rearsets (all the way up and back)
•   Cut air box just like this http://ducatimonsterforum.org/index.php?topic=19989.0 (pics seem to be down)
•   K&N
•   PCIII with a dyno tune - seen here http://ducatimonsterforum.org/index.php?topic=20239.0
•   14 tooth front sproket
•   Leo Vince Ti exhaust
•   Marving mid pipe with a lot of work done to eliminate exhaust leaks from joints
•   Tail chop with clear alternatives integrated signals
•   New front signals, small and super bright
•   Sharkskinz Triumph Thruxton front fairing (really easy to mount, decent wind protection when your head is way down)
•   Billet twist gas cap
•   TPO parts kickstand eliminator
•   On the bike are the stock 5 spoke Marchenisi wheels with street tires.  I have a set of Michelins rain tires I will mount and the race rubber will go on a set of Brembo 3 spoke I picked up.  I will be running Bridgestone DOT BT003 with tire warmers.
I am racing as a novice in the novice races, and in the www.ducaticup.com as novice's are allowed to race in this series.  The Ducati Cup has a HP limit of 118, perfect for a complete stock 848 but about a 48HP deficit for me.  My priority is to learn, have fun and to finish.  For those of you unfamiliar with Calgary's soon to be closed racetrack, the pavement in your local shopping mall is way better than the track here.  Cracks large enough to swallow a tire are not uncommon.  The straight is also very long so anything 600cc (inline 4 and bigger twins) and above destroy me on the straight.  I do catch up to them in the corners however   [moto]
I have decided to keep the front signal lights and tail light in place as this bike it still street legal; I have them taped for the track.  From race trim to street trim take about an hour including the wheel change.
I melt the crap out of my right boot on the Leo Vince pipe.  You can see the header tape I have added in a lame attempt to prevent this.  Has anyone found a solution to this problem?  The exhaust tape really doesn't work.
Other than the lack of straight away speed I am very happy with the bike and confident in its cornering abilities.   First round is May 23rd…wish me luck!
KNG
The pit:
Behind my bike is a 848 race bike and his backup 1098R.  The 848 had a clutch spring problem so he ended up using the 1098R for the rest of the day.
S2R800 race bike.  www.ducaticup.com
I wish you good luck [thumbsup] very cool [moto]
Did you change pads or anything to improve your brakes?
killerniceguy
I haven't yet.  I have a set of Brembo gold line masters sitting in the garage.  If I can find some of the matching calipers and rotors (2 sets) I will do the switch.
Quote from: stopintime on May 10, 2009, 02:22:22 PM
yotogi
As to the melting boots. It looks like you midpipe is missing the attachment point for the boot guards? Should be something you could get welded to the pipe to keep you heels off the hot.
Congrats on the buildup and good luck!
mookieo2
Gus Duc
Good luck [thumbsup]
And add some oil....... looks low in that first pic :o
killerniceguy
It is running ;D
Quote from: Gus Duc on May 10, 2009, 05:51:51 PM
Gus Duc
killerniceguy
Finished Round 1 on May 24th.  Here are some action pics.  Got crushed by the 600's on the straight but were able to reel most of them in through the corners and occasionally pass one out of the bus stop.  Lots of fun and the monster did great considering the 50hp deficit  [moto]
Scottish
 [moto] Cool beans, cool action shots!  [thumbsup]
corey
great action shots!
love the dandelions, they add a nice touch to the scenery... hah.
nice number plate choice too. 66 is one of my favs..
fasterblkduc
Way to go! great update [thumbsup] I'm glad to hear you've got the bike out there. Have fun [beer]
Atomic Racing
Zalusky Advanced Riding School Lead instructor
2010 partners:
Komodo Gear, Motorex, Studio299, Moto Primo, Caztek, Chickenhawk
csp808
Very sweet which clip on set up are you using with those reservoirs?
killerniceguy
The speedymoto clamp style.  Very tight clearances but possible.
KNG
Quote from: csp808 on June 07, 2009, 04:38:03 PM
That Sharkskinz flyscreen looks like an upside down welders mask.  Looks something like that off of a Buell.
Looks like it just covers the headlight.
